Results 1 to 38 of 38
    Oct 27 2015
    San Diego, CA
    What happens when...
    You try to use the parking brake while in motion?
    I know, silly question, but I wondered as my parking brake in my WRX saved me from an accident on I-5 once. I was driving from LA to San Diego at the time. As I came up on slower traffic near La Costa, I went to brake and was met by the pedal going almost straight to the floor. I was able to use a combination of downshifting and the parking brake to avoid an accident and get off the freeway to a gas station. There I discovered that the front left brake line had been left rubbing against the inside edge of the rim by the tire shop that had installed new tires a couple of days earlier. It ended up rubbing all the way through the stainless steel line and spewing brake fluid all over the wheel well. Was definitely an adrenaline pumping experience. Remembering it made me wonder what would happen in a similar situation with the S4?
    Oct 11 2012
    San Martin CA
    try it rolling in a parking lot?
    2014 S4 DSG, APR stage 2, APR DSG tune, 034 Intake, real dipstick.
    Apr 05 2016
    Portland, OR
    I don't think you can engage it with your foot off the brake.
    You can disable this check with VCDS but I am not sure why you would.
    You might be able to slam on the brakes and hit the parking brake simultaneously. Not sure what the car would do though.
    Go find an empty parking lot and find out.
    Geoff
    Veteran Member Four Rings Bruno_s4's Avatar
    Mar 12 2010
    Richmond Hill, Ontario
    Weirdly enough I was wondering the same thing earlier this week....
    2010 Sprint Blue S4 DSG | Sport Diff | GIAC Stg 2 + TCU | S4Matty ported charger/throttle body | PLM | AWE Touring + Resonated DP | ECS Kohlefaser | H&R Clubsport RSS | Renn Motorsports RS-51 19 x 8.5 | Super Sports | Stoptech ST60 BBK | Endless RF650 | 034 X-Brace | CR-15 | 034 Rear Bar | 034 Rear Diff Inserts | ENLAES Spoiler | Driving Passions Diffuser| RS4 Grill | STVBEK Front Lip | Clear Corners |Philips Ultinon 6000k | G6 6500k LED Fog | FBSW | JL Audio 10W6v2 | 500/1v2 | LC2i
    Veteran Member Three Rings silverf0x's Avatar
    Dec 14 2015
    Montreal, QC
    Quote Originally Posted by Bruno_s4 View Post
    Haha me too!
    I sometime engage it while not fully stopped, like maybe 1-2 miles per hour and it engages and brakes really hard! I don't know about higher speed tough..
    Murdered B8.5 S4
    Build Thread
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Interesting thought. Since old school E brakes were basically connected directly to the cable, you were able to modulate pressure. Would the ECU modulate it for you, or would it simply go full lock and kill you faster? Lol. I imagine they engineered around option 2. So what happens, and how is it done?
    2021 Audi S4, P34 Intake
    Dec 10 2012
    New York
    From my understanding, if you engage as normal while moving you will hear an audible warning and the mechanism will not engage. If you hold the switch up, however, the car will interpret this as an emergency and maximum braking force will be applied. I have never tried it though.
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    I tried it in my C5 A6 and it beeped and the dash went nuts but it still grabbed. Haven't tried it in my S4's though
    Senior Member Two Rings JustPlaneChris's Avatar
    Jun 09 2016
    1998 Mazda B4000
    Austin, TX
    From the owner's manual, page 87:
    Chris
    2014 S4 - 6MT | Brilliant Black | Black Optic | Carbon inlays | Alcantara | B&O | CR-15 Strut Brace | 034 Intake Hose + K&N
    Veteran Member Four Rings SilveR316's Avatar
    Jun 02 2013
    Downtown Toronto
    As stated above, it acts like an emergency brake when you're traveling at speed.
    Give it a try the next time you're driving around. Just make sure there's no one behind you!
    2017 S6|Sepang Blue|Black Optics|Silver Mirrors|ASC WiFi Module|AWE Exhaust|034 Drivetrain Mounts
    2014 S4|Prestige|Estoril Blue|6MT - AWE 102mm|Alu Kreuz|KW H.A.S.|SPC Control Arms|20x9.5 Vorsteiner V-FF 102|Vorsteiner Front Spoiler|Deval Valence - Build - SOLD
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    I have tried it before, if you tap it nothing will happen. But if you hold it for longer then a second be prepared to stop.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Mar 21 2015
    Quote Originally Posted by JustPlaneChris View Post
    Thank god for car manuals, now if we could just get everyone to read theirs then there would be twice as less posts on here.
    Oct 11 2012
    San Martin CA
    So if you had brake failure like the op where a brake line has burst, does this still work?
    Jun 09 2016
    1998 Mazda B4000
    Austin, TX
    Quote Originally Posted by damnbiker View Post
    Nope, since (and I quote the manual again) "The vehicle is braked at all four wheels by activating the hydraulic brake system."
    Chris
    Mar 21 2015
    Where can owners find their manual?
    Jul 05 2015
    Lower Hudson Valley
    Doesn't the S4 have a dual diagonal split-service hydraulic brake system?
    Jun 09 2016
    1998 Mazda B4000
    Austin, TX
    I can find mine in the glove box.
    Oh, and also online (by providing the VIN) at http://ownersmanual.audiusa.com/
    Chris
    Oct 27 2015
    San Diego, CA
    Thanks for the feedback. I must admit that while I've browsed the manual, I haven't read it cover to cover. Sounds like in the event of a brake line failure things would get exciting in an unpleasant way.
    Jun 09 2016
    1998 Mazda B4000
    Austin, TX
    Quote Originally Posted by SDBolts View Post
    I think we can all agree on that, manual-reader or not!
    Chris
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    I've done it. It's like throwing an anchor overboard. God bless loaners. LOL
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Apr 05 2016
    Portland, OR
    I tested this on the way home. Tapping it at highway speed gives a beep. Holding it drops the anchor.
    Tapping it at 25 gives a beep and light braking. Holding it again drops the anchor.
    Good to know and not something I've thought about before.
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    Always wondered this.
    Ok - here's another one: If you open the door going pretty slow (less than 5 mph), the parking brake is engaged. What happens if you open the driver's door going 25mph?
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Quote Originally Posted by Acejam View Post
    I have opened my door at 50 and nothing happened. Wasn't fully open but a decent crack open and close
    Jul 11 2016
    2001 BMW R1200C, 2001 SeaPro w/115 OP
    Englewood FL
    Literally just learned this today. Rolling through a parking lot and saw a plastic bag, slowed down and opened my door to grab it off the pavement (drive by style) and the car abruptly stopped. I was like wtf just happened?!?!?
    '15 S4 | Sepang | Alu Kreuz | CR-15 | 034 DP ECU/TCU | XLR8 196.5mm | HPFP | Merc HX | 034 rear sway | 034 Full inserts | Dinan Coilovers | ECS Kohlefaser Luft-Technik |
    Veteran Member Three Rings Luna's S4's Avatar
    May 22 2013
    Cannondale, two Orbeas & a Trek
    Northern Cal
    Quote Originally Posted by mrmomo313 View Post
    Why? Just wondering.
    2011 S4 DSG Prestige w/ Revo! Bilstein B16 PSS10! H&R RSB! AP Racing BBK! Michelin PSS!
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    I legit read the manual front to back on every car that I get. Some stuff gets repetitive over the years, and some things you learn.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    you do realize your curmudgeon posts are just as useless as the posts you continually complain about all of the time right? you need to learn to let shit go man its all small stuff...
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Jul 31 2014
    Mpls, Mn.
    shoulkd have at the least a dual reservoir master cylinder setup, where as you would have to have leaks or punctures in both lines to lose full brake function, and even then on older vehicles the e-brake was mechanically linked as a fail safe, i would imagine audi has something similar but idk?
    Mar 21 2015
    Quote Originally Posted by Johnnycash View Post
    In the real world it is small stuff and I agree with that. In this AZ world its huge that the amount of people waste the time to post stupid questions when all they had to do was open their glove box or search for 5 minutes. I agree that I do need to let it go sometimes but it depends on my mood that day with when I give a response like this. People are lazy as shit and don't think about anything. We all are guilty of it, not just me. I know you might think it, you just don't say it. If you think my few complaining posts are useless then go check out that 60 page thread with APR.
    Oct 27 2010
    Michigan
    Quote Originally Posted by Luna's S4 View Post
    I was out testing/logging. Car misfired and disabled all cyls but one... Car becomes extremely slow when that happens. I popped it in N. Turned off the car, opened the door and closed it quickly to reset everything and turned it back on... Code was cleared and a had full power. Pulled over and then cleared all codes with vcds
    This happened in my testing area so no one was around.. I just hate driving the car in limp mode longer than it needs to be.
    Senior Member Two Rings Quidproquo's Avatar
    Aug 06 2015
    2013 Audi S4, 2007 Nissan 350Z Enthusiast
    Morris County, NJ
    Quote Originally Posted by Helmet165 View Post
    I had the same thing happen when I opened the door to get a parking lot ticket out of the toll machine. I close the door and my e brake is on.
    Then I realized I can just touch the gas to get it to release. However, if your seat belt is off, it will continue to detain you!
    2013 B8.5 S4 DSG (034 Motorsports intake tube | air box mod | aFe Pro Filter | CTS+183mm Iabed Pullies | EPL Dual Pulley 93 Pump Tune | SunTek 35% Tint | 19" S5 Rotor Wheels)
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    You beat me to it. I was going to say something similar. ;)
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Mar 21 2015
    Quote Originally Posted by doughboy17 View Post
    Thanks for the back up lol
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    ...when all they had to do was open their glove box or search for 5 minutes.
    But it makes soooo much more sense to post a question online and wait 2 or 3 or 10x longer for an answer (or sarcastic remark)
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
    Apr 14 2016
    Austin Texas
    Half as many?
    Sent from my Venue 8 7840 using Tapatalk
    May 22 2013
    Northern Cal
    Sounds reasonable to me! Wasn't trying to persecute you. Was legitimately interested in the door opening at 50 mph. Cheers!
    Mar 21 2015
    Quote Originally Posted by chet.rowles View Post
    Half as many?
    Lol, I did second guess myself when typing that. Thanks for that.
    May 10 2012
    2013 s4, 2008 cbr1000rr
    United States
    Math
