Results 1 to 13 of 13
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    Cool Dash pods for gauges
    I have a friend who makes these and I thought I might share this on here, Moderators please let me know if this is not allowed and remove the post if necessary,
    He can make these for A/S/RS B5/B6/B7 and C5
    standard 52mm or 60mm if requested can do a combo of the sizes also. HVAC pods and RHD pods
    B6/b7 defroster vent gauge pods are finished. Can do single and dual pods. Message to order! $95 USD and shipping for single, $115 USD and shipping for dual.
    Can do any color of your choosing.
    10% off on all prices until this Sunday 9/18/2016
    [email protected] just reference my name, Terry Reese
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    Can you ask your friend if, he can make one for the B5 S4 platform?
    Oct 05 2015
    Billings, MT
    he can. as stated in the top part, he can make for the B5/6/7 and C5
    *updated info. Thanks for pointing that out.
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    hmmm what gauges do I need now.... hmmmmm
    #turbolife #boostrunsonparanoia
    Oct 05 2015
    Billings, MT
    Shoot him an email, nice guy and makes sturdy work, I got some keychains from him. solid material. Just tell him I referred you. Terry Reese
    Jan 29 2010
    north ga
    Am I the only one who thinks those are ugly as hell?
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by BCsniper View Post
    I don't think I've ever seen a "pretty" gauge pod. After all the gauge face and bezel block the view of most all of it ;)
    Oct 09 2008
    Nope. And they look like 3D printed ABS plastic, which I believe gets brittle when exposed to UV light. Maybe I am wrong, but I'd be worried about them falling apart after awhile.
    The Awesome™
    Oct 05 2015
    Billings, MT
    The wall thickness and infill percentage is high enough to prevent deterioration. Also that there has been a customer in Arizona that reports NO malfunctions, even in the desert heat/sun.
    Sep 28 2013
    United States
    Hey all! I'm the one that actually makes these pods.
    I'll address a few concerns.
    As these are 3D printed and not injection molded, they don't have the same completely smooth characteristics.. There are pro's and con's to each method of manufacturing.
    My pods are significantly cheaper than all the other options on the market. I do, however, offer a limited lifetime warranty; that if anything should go wrong with the pod, not of your own doing, I will replace it free of charge.
    Also, UV degradation is not a huge concern as glass completely blocks UV-A light, and most windshields effectively block UV-B rays. If there were to be ANY degradation it would only be on the surface of the item, yet it would still retain structural stability. As mentioned, I've had multiple customers in some of the hotter areas of the country that report NO issues with the pods being in the sun and heat.
    Established Member Two Rings dmanisgnarly's Avatar
    Nov 05 2014
    Supermotos & Sportbikes
    The East Coast, NC
    I am also a 3d printer. While these do look good I wouldnt use PLA or ABS in my car parts. Consumer available filaments are still not of the same quality as OEM plastics. Most filaments are imported from china and there are no quality control procedures set in place like in the metallurgy world. I applaud your engineering abilities as I am still learning the ins and outs of cad based design. Cant beat making 100 bucks off of 5 dollars worth of filament.
    2005 S4//K&N/Pod filter/Carbon MAF extension/APR Carbon NACA ram-air duct/JHM intake-mani spacers/Gutted piggies/Custom Catback/034 Motorsport billet engine mounts/19” Peelers/034 Snub/Neuspeed lowering springs/JHM stage 4 Kevlar clutch/Rallyarmor mudflaps/Rocketbunny V2 front diffuser/canards/HIDs/DRLs/LEDs/trailer hitch
    02' A4 1.8T Quattro
    Sep 28 2013
    United States
    I use HatchBox filament and from what I can see, they have strict quality control measures.
    It's not so much the value of the filament, as it is the production time to make these pods. It's about a 13-15 hour print job, per pod. Consider electricity, miscellaneous supplies, time, and $100 for 13-15 hours equates to less than $7 an hour.
    Oct 05 2015
    Billings, MT
    bump for those looking for something like this.
