Results 1 to 18 of 18
    Oct 30 2006
    Kildeer, IL
    2004 Allroad Stage 3 for sale or trade
    $9k or trade
    All work was done within the last 8 months. I have approximately 50 miles on this setup. I purchased the Allroad completely stock.
    Will include a lot of extras with the sale / trade. Including most of the items that came off from the manual swap as well as a bunch of extras like a complete black dash swap and s6 steering wheel and airbag.
    Alpaka 2004 Allroad
    178k miles
    Clean title, title in hand
    Air suspension works fine
    Exterior has some small nicks and a few small door dings. There are a couple dings in the hood.
    Interior has some nicks in the pillars and headliner from previous owner. He used it to haul lumber and had a pretty big dog. It was purchased completely stock with a blown torque converter.
    Converted to manual. The car is quick. Hasn't even had an updated tune from Motoza. It's on a standard flash. Just had the front windshield replaced. Tires are like new on original allroad wheels. The wheels have clear coat wear, but are straight and no evidence of curbing. The SAI system and the front head light wash sprayers have been deleted.
    I would call it a sleeper, but you can't hide the front mount and the rear tail lights are light smoked. It does have a stock exhaust system.
    JH Motorsports FMIC Kit
    Frankenturbo F21 turbos. Just rebuilt.
    Frankenturbo lobster claws
    Bosch 550cc injectors with new orings
    034 Phenolic Intake Manifold Spacer Kit
    034 SAI Block Off Kit
    034 Silicone TBB
    034 BiPipes Wrapped with Heat Reflective Tape
    90mm Intake + MAF adapter with Dry filter
    Gates Racing Blue Timing Belt
    New OEM water pump
    New OEM pulleys and tensioner
    New Continental Serpentine Belt
    New seals throughout (front and rear main, all camshaft seals and plugs, tensioner seals, valve cover seals)
    Swapped to Aluminum Thermostat Housing
    New OEM Thermostat and seal
    New fan switch and temp sensor.
    New ignition coils. All replaced.
    Bosch FR5DTC Spark Plugs
    JHM fan delete kit with electric fan conversion
    New Bosch Alternator
    New OEM Starter
    New OEM dual mass flywheel
    034 Auxiliary Coolant Pump Delete
    034 Silicone Turbo Hoses
    Clutchmaster Stage 3 Clutch Kit
    034 Clutch -3AN Adapters
    -3AN Braided Clutch Line
    New slave cylinder
    034 Shift Link Bushing
    Redline Gear Lube in Rear Differential
    OEM fluid in transmission
    Silicone Vacuum Hoses Throughout
    New OEM Coolant Hoses
    SRM Catless Downpipes
    New Front Allroad Half Shafts
    Allroad Front Output Transmission Flanges
    New Front Wheel Bearings Driver and Passenger Sides
    New Front Brake Rotors Driver and Passenger Sides
    New Front POWER STOP 16915 Evolution Ceramic Brake Pads
    New Rear Brake Rotors Driver and Passenger Sides
    New Rear POWER STOP 17340 Z17 EVOLUTION PLUS Brake Pads
    New Driver and Passenger Side Inner Tie Rods
    New Driver and Passenger Side Outer Tie Rods
    Apikol Race Rear Differential Mounts
    034 Street Density Engine Mounts
    034 Street Density Transmission Mounts
    034 Driveshaft Support Bearing
    034 Aluminum Fuel Pump Bracket
    Walbro High Output Fuel Pump
    Brand New Bosch FPR
    New Bosch Fuel Filter
    034 Snub Mount
    Motoza Software Upgrade / Flash with software and cable.
    Advanced Automotion 6speed harness
    710N Diverter Valves
    ECS Tuning Braided Brake Lines front and rear
    Hayden power steering cooler
    Another $300-$400 in OEM bolts (i.e. Turbo to manifold and turbo to downpipe + new banjo and crush washers for oil and coolant lines) and Oetiker pinch clamps (OEM clamps). Plus high torque full stainless hose clamps throughout.
    Have receipts for pretty much everything.
    03 RS6 - eurocharged / forge / MTM / milltek / wagner / venair / 01e swap on deck
    Jun 07 2007
    Livermore, CA
    No Price, location one can get from the license plate maybe?
    What's the story with all the interior bits, is the car interior in pieces or you just happen to have extra interior bits?
    Thanks
    Oct 30 2006
    Kildeer, IL
    Sorry. Updated the ad. The extra dash stuff is a complete black dash out of a s6, which is included with the sale or trade of the Allroad.
    Oct 30 2006
    Kildeer, IL
    Price drop to $8500 and includes brand new wheels, tires, and spacers
    https://docs.google.com/document/d/1...hRuevNSm08lUuk
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    What are you looking for on trades?
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Oct 30 2006
    Kildeer, IL
    Quote Originally Posted by melomandn View Post
    What do you have?
    Sep 28 2014
    Iowa
    Are you looking for stock cars in trade or upgraded ??
    Nov 08 2010
    Upstate New York
    Quote Originally Posted by terrytcl View Post
    What do you have?
    B6 S4, great condition, timing chains have been done, I have extensive maintenance records all the way back to the original window sticker
    - B8 S4, Stage 2+
    - B6 S4, not stock
    Oct 30 2006
    Kildeer, IL
    Quote Originally Posted by 714Knives View Post
    Depends on the car
    Oct 30 2006
    Kildeer, IL
    Can you send me more details?
    Oct 30 2006
    Kildeer, IL
    Oct 30 2006
    Kildeer, IL
    $7500 as it sits with new wheels and tires
    Junior Member One Ring
    May 01 2011
    How is rust on this vehicle ? Any check engine lights on ? Some interior pics would be good.
    Oct 30 2006
    Kildeer, IL
    There's some slight surface rust on the front and rear subframe. Yes, has CEL for removed SAI system. Tuner said they can code it out as long I have the rear oxygen sensors in, so that's why the rear oxygen sensors are still installed.
    Oct 30 2006
    Kildeer, IL
    See link for pics
    Oct 30 2006
    Kildeer, IL
    https://drive.google.com/open?id=0B-...Vgwb3RVQ3lOM1E
    Senior Member Two Rings pjhock5's Avatar
    Sep 20 2009
    997 Porsche 911 Turbo Stg 2 6mt, c5 allroad Stg 3 6mt, MK1 R8 6mt, Mk2 TT s-line VR6 6mt
    Mitten
    Still available? PM sent.
    Oct 30 2006
    Kildeer, IL
    Quote Originally Posted by pjhock5 View Post
    Responded. Thanks
