Results 1 to 13 of 13
    Nov 30 2014
    Dallas, TX
    Smoke in the cabin!!
    This first happened yesterday, I was following a bus so I thought maybe the exhaust fumes got in but it happened again when I was parked in a parking lot.
    I can't tell what type of smoke it was, it was night time so I couldn't really tell the color of the smoke. I'm fairly certain it smelled like fire smoke not coolant smoke but I'm not sure :( it happened so quickly, I panicked and put the windows down to let it out.
    Has anyone ever had this happen? The smoke came in from the passenger's side, I'll be checking for coolant leaks later today, I had a huge coolant leak last week, one of the hoses was missing a clamp and it spilled almost ALL of my coolant on to the area near the air intake snorkel. Got on the engine and evaporated, really scared the shit out of my mom who was riding in the car with me lol.
    If it was caused by an electrical problem, wouldn't it blow a fuse? So far no errors on the dash, and no CEL's, I've scanned it with VAGCOM.
    Also, I have seen smoke coming from the engine bay but it was in small puffs, only saw the puffs of smoke when I noticed smoke inside the cabin. Any help whatsoever would be very much appreciated!! I'm scared...
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    so smoke entered the cabin with the windows up?? Only thing that could be is electrical. Coolant of course has a very distinct smell and you'd most likely have a wet floor if it leaked enough to be noticed. Just my two cents.
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Broken flex pipes ?
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Veteran Member Three Rings JB5's Avatar
    Jul 19 2010
    96 B5 A4- Sold, 06 corollaS (wife's), 97 Ford Ranger, B6 A4 (Daily Driver)
    Snellville, GA
    sometimes you can see what appears to be smoke but it's actually humid air. when yo blast the AC in a very humid day, it could happen.
    Nov 30 2014
    Dallas, TX
    http://imgur.com/zhVdDqs
    Electrical smoke...
    Has this ever happened to anyone? It looks like the harness on the positive terminal shorted out.
    Apr 26 2016
    Kia Sportage V6 - Wifes car
    Metuchen New Jersey
    I would say that's probably the cause of your smoke, not sure about audi's, but on American cars, smoke could enter through the ducts.. i would imagine if you have the vents on fresh air, it could enter that way.. or if that was the last setting you used even..
    Sent from the S4 with a Tap!!!
    My S used to have a tap, a valve slap... now it makes no noise at all! RIP
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    I had a little bit of coolant collect on my exhaust manifold... it smoked for a few days after I did my downpipes.... nothing entered the cabin though. Electrical smoke has a distinct smell.
    Jun 07 2013
    West
    Serious, serious issue. Don't mess around. Take it to an Audi dealer's service department and have them check everything. This is very unusual and don't dismiss it if you no longer smell smoke.
    Apr 18 2012
    1995 Toyota Land Cruiser (FJ80/FZJ80)
    Central Texas
    crikey! the cabin air intake is right next to the battery, so it likely sucked in the smoke from that meltdown.
    i would IMMEDIATELY disconnect both sides of the battery and start diagnostics or consult a mechanic. you don't want that lighting off in your driveway - or apartment garage!
    - emilio
    Nov 30 2014
    Dallas, TX
    Cars parked at work, did not risk driving it anywhere, I have a friend who's a mechanic so he came and checked it out. He's not sure what the cause was but he's going to redo the positive terminal of the battery.
    Funny thing is I had the car at an Audi dealership a month ago for them to have a look at my electrical system. I was having trouble starting the car after it had been sitting overnight or sitting at work, they looked at the battery, alternator and starter motor and said it was all good.
    Apr 18 2012
    Central Texas
    i would definitely inspect the entire engine electrical system before repairing that battery cable.
    the starter problems are likely related. the only thing that could cause a meltdown that big is a very large un-fused short at a device designed to consume a lot of power - say, a device like the starter. it would take a huge amount of power to smoke a battery cable like that, so big that it would melt most electrical systems in the car before it affected the battery feed cable. the starter is probably the only device in the car capable of drawing that much juice without melting.
    - emilio
    Nov 30 2014
    Dallas, TX
    Thanks emilio! That's my suspicion too. I'll have the mechanic have a look at the starter motor before trying to start it. Luckily my car is a stick so we can always push start it and bypass the starter motor for now. Might have to have the starter motor replaced very soon.
    Nov 30 2014
    Dallas, TX
    So the previous owner was a DIY type of person so I'm guessing he installed an aftermarket stereo, amp and sub himself. He didn't too a very good job cos I had a pretty bad grounding issue, I cannot believe my starter motor, alternator, coil packs or anything else electrical wasn't affected. My positive terminal blew because of a combination of the wiring and sheer bad luck, some leaves got stuck in the drain hole below the battery (oh and whoever installed it - previous owner most likely - didn't f-ing bolt it down so the battery was moving around with the bumps) so when it rained a few days ago, water pooled in the area and so what resulted was a blown battery, blown positive terminal and wire length, and a very scared (now, relieved) owner.
    My mechanic re did the grounds so I shouldn't have any issues going forward (fingers crossed) and thank god my starter motor is ok cos that would have been more $$
