Results 1 to 8 of 8
    Senior Member Three Rings Gmoney1147's Avatar
    Dec 09 2014
    Roseville California
    Dumb question...
    So I installed a test pipe 3 weeks ago. Was curious if I need to do a retune now? One of my buddies told me I should.
    Veteran Member Three Rings StatusQuo's Avatar
    Jun 15 2016
    Northern California
    Quote Originally Posted by Gmoney1147 View Post
    What tune do you have right now? What stage and what brand.
    B7 Audi A4 Quattro - Built. Not Bought.
    Upgraded HPFP | RS4 Injectors | RS4 LPFP Controller | 175 Bar PRV | 50/50 E85 | Straightpipe Exhaust | Cold Air Intake | Big Turbo | Front Mount Intercooler | -- The Maestro Community Project --
    Dec 09 2014
    Quote Originally Posted by StatusQuo View Post
    It's a stage 1 tune from vagautowerks. It was tuned when I had my cat on.
    Jun 15 2016
    Northern California
    Yeah you are gonna need a retune in that case
    Dec 09 2014
    Even if they said it was fine ?
    Jun 15 2016
    Northern California
    If the tuner said you are fine, then you are fine.
    Jun 18 2015
    DavidhogAJ
    Philippines
    Although it is a LOT more flow going from stock cat to test pipe (it was stock, right? Not a HFC?), the tune can adjust for the additional flow.. It's only when you do more mods like upgraded HPFP you will want to get a new tune to take advantage of the extra fuel available, etc.
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    Quote Originally Posted by danbfree View Post
    this, the ECU can handle it.
    I run my ''stage 2 ready'' for a while just before I flash the ECU. I was on stock tune.
    0 issue.
