Results 1 to 40 of 40
    Senior Member Two Rings lowjonathan's Avatar
    Jun 30 2015
    Interest check for those want to divorce the HE coolant loop with simple reservoir
    Just to check out interest for those who want to divorced the HE coolant loop from the cooling system.
    have spoken to manufacturer, he mention he do need some numbers to keep the cost down for everyone.
    The kit will be a simple reservoir with some piping and bracket.
    Target price $100
    the small black reservoir will be something like page 13/14
    http://www.goapr.com/support/install...8s4_cps_v2.pdf
    **those who need the HE combo kit (HE+alum tank) for AZ member special buy is still on going...PM me for his email
    Volk racing G25
    KW v3
    Hotchkis ARB
    034 adjustable upp arms
    034 tranmission inserts & mount
    Uprated front bushing.
    CTS intake kit
    CTS SC pulley
    KI 184mm crank
    Custom tuned with DSG remap
    Nov 28 2015
    Montreal, QC
    i would be interesting as I got a PLM kit myself. 100$ seems a bit step tho for rubber hose no ?
    S4 B8.5 no track, just enjoying spirited driving.
    Jun 30 2015
    Quote Originally Posted by waxxonMTL View Post
    it will be with alum tank, bracket and some small piping
    i am trying to get the number of interest so it can be get going.
    especially for us on PLM kit.
    Volk racing G25
    KW v3
    Hotchkis ARB
    CTS intake kit
    CTS SC pulley
    KI 184mm crank
    Oct 08 2007
    Minnesota
    I'd be interested at that price
    2014 RS5
    2012 S4 DSG EPL Stg 2 DP
    B5 A4 Lemons Racer 2019 Minneapolis 500 "pray for rain" Award winner
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Any feedback you can give on the PLM? Any significant gains?
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    Can someone please explain what this will do? Cause for $100 I'd be interested
    Sep 20 2006
    MD
    Quote Originally Posted by Pyromatic177 View Post
    This is intended to separate the coolant circuit that cools the engine from the coolant that cools the supercharger. This is what they called "divorcing". To make this happen, the supercharger needs it own coolant circuit/loop and reservoir. The $100 gets you the hoses, reservoir, brackets to divorce the systems.
    Established Member Two Rings tars9's Avatar
    Jun 15 2015
    Schaumburg/IL
    Interested. Would need to comply with b8 with PLM and ADS.
    2012 Audi B8 S4 | 6MT | Phantom Black | Kohlefaser Luft-Technik Intake l AWE Track Exhaust & Resonated Downpipes l Mertop Long-Tube Cat-Less Headers I EPL Stage II+ l Pulley Ratio 3.28 l PLM HE & Reservoir l ECS Trans and Rear Diff Mounts l CR-15 l P3 VIDI
    Aug 02 2015
    Corning NY
    Quote Originally Posted by RLB6 View Post
    Thanks. Can this work with the stock system? For now anyway.
    Sep 20 2006
    MD
    Yes.
    Mar 04 2010
    95.5 Audi S6 Track car 2010 S4 with mods 2006 Audi A4 2.0T S line w/ mods, 1974 Alfa Romeo 2000 GTV
    NY/NY
    I would be interested, if the reservoir is larger than the current one I run on my APR system. BTW, you are also going to need a silicon bypass nipple for one of the pipes at the reservoir, regular rubber bypass nipple will not work. They start cracking right away.
    2019 Ara Blue RS3, APR Stage 3, DSG tune, UM Haldex tune, TTE700, APR 4" turbo & throttle inlet, rear carbon tube, pendulum mount & dogbone insert, Tyrolsport Front Deadset Kit & Harness bar, Superpro LCA bushings, CSF radiator, JDY Performance oil pan, APR FMIC, Race Downpipe, catted Mid Pipes, Milltek exhaust, Wavetrac LSD F&R, KW Clubsport 4 coilovers, Neuspeed tubular sway bars and 350mm rear rotor kit, AP Racing CP9660 BBK, RSE11R 18X9 45mm offset wheels, 265/35 Michelin Pilot Cup 2 squared
    Veteran Member Three Rings Jflow23's Avatar
    Apr 10 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    Definitely interested...been posing this question for a while. Lowjonathan, thanks for reaching out to PLM...I hope they elect to take on this project.
    Jun 30 2015
    Quote Originally Posted by rcaro900ss View Post
    So u refering to the bigger square reservoir on PLM combo kit now?
    https://www.privatelabelmfg.com/heat...-reservoir.htm
    reaching out to get smaller one as APR current
    which Jflow23 has did up his own small reservoir. He is running divorced HE Coolant loop for sometime using his custom HE.
    thanks
    Volk racing G25
    KW v3
    Hotchkis ARB
    CTS intake kit
    CTS SC pulley
    KI 184mm crank
    Mar 04 2010
    NY/NY
    No, that is not the reservoir on the PLM site. I am looking at the overflow/fill reservoir on page 13 of the APR information. I wanted something larger that what I already have.
    Jun 30 2015
    i see, maybe i can let PLM guys know to make it bigger.
    do u have any idea what is your current one capacity?
    tks
    Volk racing G25
    KW v3
    Hotchkis ARB
    CTS intake kit
    CTS SC pulley
    KI 184mm crank
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    I think you guys will find what most others have.... Just divorcing the system does very little. There is only one location where they meet, and that's at the overflow tank. Otherwise they are two separate loops already. So, the only chance for the two systems to exchange fluid is when there is overflow; even then it would be a very small amount.
    The downside is once you divorce the system (disconnect the S/C loop from the overflow tank), you will loose the ability to know if there is a leak on the S/C loop which can be an important thing to know for several reasons (a leaky intercooler can destroy an engine, and running out of coolant can destroy a S/C). I'm actually surprised APR and AWE still offer this as an option (although, I'm going to guess the new APR system will not).
    A local owner recently divorced his system, and found no discernible difference with or without it divorced. I think this was one of those things that sounded like a good idea based on how other platforms benefitted, but once you really dig down into it, this particular platform essentially has a divorced system already.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Dec 01 2013
    '93 RX-7
    San Francisco
    Quote Originally Posted by jran76 View Post
    Did the guy with the divorced system change anything else? Would a larger reservoir help add more cooling capacity more than the divorced system?
    2012 S4 MT6 | Prestige | Sports Diff | Phantom Black Pearl | Black Optic Package | Titanium Package | H & R sport Sways | CR-15 | CTS Intake | EPL Stage 1 | 034 Track Spec Upper Control arms | 034 drivetrain/trans inserts | JHM Shifter
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by SonnyDeez View Post
    No, he already had the AMS/Alpha coolant system (heat exchanger, pump, res).
    A larger reservoir absolutely makes a big difference. It greatly expands the thermal capacity of the system. In order of impact, a larger core/radiator/heat exchanger makes the biggest difference, then a large reservoir, then a pump, and then divorcing the system. I think most of the guys here have a larger heat exchanger and reservoir (that is essentially what the PLM system includes). PLM, APR, and AMS/Alpha include a larger reservoir. Revo, AWE, and Forge do not.
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    And, to be clear.... Divorcing the system does do something; just very little. Maybe a one or two degree drop at the most. To me at least, the potential downsides (cost, monitoring coolant loss, etc.) is not worth that. For some people, it might be I suppose. Without a doubt, heat is the enemy of performance more so on this platform than most, and the dual pulley cars need all the help they can get.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I am with you that is why I went with the AMS system. I DD my car and not knowing there is a problem before something happens is not acceptable for such a minor potential gain.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Nov 28 2015
    Montreal, QC
    the reservoir of the plm look bigger than other, so that might be a good thing.
    thanks for the explanation ! I guess i will stay undivorced then.
    Apr 05 2016
    Portland, OR
    AWE has an add-in RES, granted it is not huge.
    Geoff
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by whiped View Post
    I think that reservoir functions more as an expansion tank for the S/C loop than it does a lot of added capacity. There's is a neat concept, but quite a bit smaller than the others.
    Jan 26 2015
    2017 XC90, a workbench
    CO
    I'd be interested since I am not happy with the fit and finish of my solution. However I would want it to hold about a pint though.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Jun 30 2015
    tks alot to jran76 for sharing the pro and con of divorcing the SC loop.
    it is more for the PLM users with already have the bigger square reservoir come with the combo kit.
    over at the other side "AR", one of the divorced user commenting the both loop coolant temperature difference as much as 35F durig tracking.
    jflow23 has make his own small reservoir and notice his custom HE is cooler.
    Just to share for the coolant checklight to light up, the plastic tank coolant level is way below min level.
    tks
    Volk racing G25
    KW v3
    Hotchkis ARB
    CTS intake kit
    CTS SC pulley
    KI 184mm crank
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    When i was thinking of divorcing the system, i wanted to go something OEM looking. I wonder what tank APR used on the stage 3 kit.
    i also thought of using a tank similar to this:
    Helps monitor the coolant level if its clear.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Jun 30 2015
    Quote Originally Posted by infinkc View Post
    thanks alot for the info
    APR stage 3 tank look OEM.
    Volk racing G25
    KW v3
    Hotchkis ARB
    CTS intake kit
    CTS SC pulley
    KI 184mm crank
    Jun 28 2016
    US
    Ummm, no no and more no. You can lose all the coolant in the supercharger IC system and you absolutely will not destroy the supercharger. There are a ton of non-IC supercharged systems out there and it doesn't kill any Eaton blowers whatsoever. All that is used for is to lower the IAT and allow for higher ignition timing (less retard) to be run to make more reliable power. You may however burn out the water pump that's used in that system, but I want to say that the ECU may detect that and shut it down to keep it form burning out if it's not pumping fluid and just air. I'll need to look at the pdf to be sure though and I'm too lazy to do that at the moment.. Aside from that, the engine is also safe from destruction, although there's a very good change the ECU will retard timing and boost so much based on its safety parameters that you simply won't make any power and should feel the car not pulling as strong. Other than that, that's about it.
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by SwankP3RF3ct10n View Post
    It can absolutely destroy an engine by dumping coolant into the heads. I've personally seen horrible misfires from it, and had an Audi tech tell me they've seen an engine failure when the cylinder did not fully deactivate. There was also the one reported below, and the one refrenced in the below thread on AR. But hey, maybe they're all lying, and you're right.... And, I'm sure coolant leaking in the S/C is good for it too.
    http://www.audizine.com/forum/showth...1#post11508265
    Jun 28 2016
    US
    No kidding, but dumping coolant into the engine due to a faulty IC core INSIDE the supercharger housing IS NOT what you were talking about or leading people to believe with what you were saying before. I can assure you that cracking an IC core within the housing and dumping fluid into the engine cylinders can happen regardless of the system being divorced or not and it makes no difference at that point. The fact remains that the IC system losing coolant will happen mostly from the failure of the external heat exchanger in front of the radiator being damaged. That's where your leaks will happen almost all of the time and that is where you will lose your coolant and not know about it if you were divorced. Hell, even if married, you'd still lose coolant that way, so what I said is still 100% correct, which is, losing coolant in the IC loop WILL NOT cause you to destroy and engine or supercharger simply because it all leaked out because your system was divorced and you didn't know it all drained out.
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    What are you talking about? I am specifically referencing a leaky I/C inside the S/C. If that wasn't clear, sorry (you did highlight that part in bold red print....). Having a low coolant indication has allowed several people to identify that issue before it became a bigger problem. I'd hope it's pretty obvious to any knowledgeable person that losing coolant in the loop would not destroy anything but IAT's. Ha. I didn't even think that'd need to be pointed out....
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    I don't want to derail this thread any further, so I'll leave it at the above. Apologies to the OP, and if I over dramatized any potential problems. At the end of the day, there is only a very small performance benefit, and that was really the point. Anything beyond that you can take as you want. Obviously, a lot of people have divorced the systems without issue. If you pay attention to IAT's, misfires or whatever else, you should be ok.
    Apr 10 2007
    Beaverton OR
    Anybody find another alternative? I was really hoping this was going to happen.
    Senior Member Two Rings acsgp's Avatar
    Jul 18 2014
    Singapore
    If you divorce the systems, don't you need an additional pump for the 2nd loop?
    2010 S4 Avant, Forged bimotos, Brembos, Revo GB tune
    Apr 10 2007
    Beaverton OR
    No...the electric pump runs the supercharger loop, the engine coolant pump is mechanical. The two loops are connected at the main expansion tank...easily divorced.
    Aug 09 2011
    Brooklyn, NY
    Update on this divorce setup.
    '16 Audi S6 4.0TT Eurocharged ECU - Current
    '12 Audi A6 3.0T Prestige - 187/57 DP Eurocharged ECU /TCU - Trade
    '06 Audi A6 3.2 Prestige - Sold
    '00 VW Jetta VR6 - Donated
    '98 Audi A4 Stage 3 - Gone
    Jul 01 2012
    14 B8.5 S4, 90 Toyota Supra turbo (575 whp), 02 Subaru Wrx (stock atm),
    North little Rock, Ar
    Any more info on this want to divorce my cooling system but not seeing much info in it or a proper way to do so
    Sent from my LG-H918 using Tapatalk
    Established Member Two Rings pabohoney1's Avatar
    May 03 2017
    Phoenix
    See where the rubber cap is, middle left? That's the main coolant loop, and where it is capped in that picture there is normally a hose that runs down to a T in the SC coolant loop by the pump. I ended up running a hose up to a small overflow tank. This post might be helpful.
    Apr 19 2018
    Brown
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    Quote Originally Posted by brownwv View Post
    This would work fine, only issue with this one is that it functions just as an overflow reservoir rather than an actual functional increase in thermal mass. You'd need a tank with an inlet and an outlet hose to get that affect. Not really worth doing IMO unless you're actually increasing your cooling capacity.
    2007 Porsche Cayman | 5MT
