Results 1 to 9 of 9
    Registered Member Two Rings
    Sep 13 2016
    utah
    Chipping an a4 2.0t?
    I've heard that you can get some serious power out of the good old 2.0t if you chip it. What are some pros and cons?
    Established Member Two Rings RG4's Avatar
    Jul 25 2016
    NJ/NC
    Search...
    2010 A4 2.0T Quartz Grey
    APR Stage II | APR Cast Downpipe | AWE Touring Exhaust | aFe Dry Flow | ECS Turbo Inlet | GFB DV+
    Established Member Two Rings AudiholicA4's Avatar
    Nov 09 2013
    Cincinnati, Ohio
    Established Member Two Rings MoonlightBlue's Avatar
    Dec 26 2015
    1999 Mercedes - Benz E320
    ^^^ although the only con I can name that probably hasn't been named is that it's still not gonna be or sound like a v8.
    - John
    Sep 13 2016
    utah
    Quote Originally Posted by MoonlightBlue View Post
    - John
    I'm not expecting too much, but I want some more power. Will it be too hard on the engine?
    Established Member Two Rings Vaks's Avatar
    Nov 20 2015
    Look into Chipwerke's Piggyback tune, I know a couple people running them on their S4 and haven't heard of any issues. Looking to get one myself if I can find some more people running them on A4's.
    Current:
    2013 Audi A4
    AudiTrueNorth | Ibis White | Quattro | RS Grille | RHO Plate | BlackVue | APR Carbonio Intake | GFB DV+ | KW V2 | AG Wheels
    Dec 26 2015
    Quote Originally Posted by soupfactory View Post
    Coming from a chipped car myself, I'd say no, if it's APR. Another option if you're willing to be one of the first, is the Neuspeed power Module. It has multiple modes, and (supposedly) turns up the boost, while allowing the ECU to retain control of knock, timing, etc.
    I do enjoy piggyback ECUs, and with Water / Meth, a HFC and O2 spacer, you may be looking at some good power. Even if you're 100% stock, they claim +50 HP on 91 octane on high boost (+8psi) mode, and seeing as we're not supposed to use anything less, better fuel will only yield better results. I'm guessing +60 or 70 HP with 93 octane and a catback exhaust, and more if you set up anything else like Water / (something) injection.
    The piggyback is like $400-something and is (advertised to be) fully removable for the case of dealer inspections.
    If you read the warranty and have no issues with the way they are required to handle things, I believe you'll enjoy this method. It's a bit cheaper than APR/Revo/Giac,etc., I believe.
    Remember, I'm not a doctor, just a (WHY GOD, WHY DIDN'T I JUST GET THE V8?!) 4 cylinder Audi driver like you.
    - John
    Jan 28 2011
    1956 Pontiac Safari
    Nashville
    I just picked up a 07 A4 with a Eurodyne maestro tuning software, currently running stage one tune from a friend and fellow Audizine member... It rips.. it also has exhaust, downpipe, injectors.. it's a totally different car, highly recommend checking it out, runs great.. I'm coming from a bone stock b6, it's not even close to the same car
    Jan 28 2011
    1956 Pontiac Safari
    Nashville
    Ohh and
    pros - power doesn't fall off in the higher revs, nothing too crazy regarding the tune..a relatively stock car should be fine without breaking anything...
    cons - occasionally I get a CEL underboost code, exhaust smell, totally worth it..
