I've looked around on other forums but can't find a definitive answer.
I replaced my cv, then decided to replace my front 175k shocks, then noticed the upper control arms are bad so am ordering those.
While I'm in there I'm worried the lower rear/curved control arm is shot at the bushing on the subframe and should replace them if at all bad.
The initial reason I tore the front end sort was my car would have a slight grinding sound on the left front that would become worse in a course of 5 seconds applying the brake at 50 mph. Then the steering wheel would shake a little too. Also, I when I go over 1 inch curbs, I would here a clunk.
Relaxed my motor mounts last week thinking that would solve it, but it didn't- though it helped the clunking young accelerations.
Soooo, my question is, now that my front shocks/trusts have been removed from both sides of my car, and the ball joint of the lower curved control arms separated from the steering Knuckle/wheel mount how can I check if those lower curved control arms are bad.
I'm almost willing to buy them just to make certain they will be good while everything is torn apart.
Below is a screen shot of the rubber on the curved control arm to the subframe.
Thanks a ton.
