Results 1 to 18 of 18
    Mar 02 2016
    Los Angeles, CA
    Acceleration Misfires
    Hey guys,
    2006 A4 Tiptronic Quattro with 95k on the clock. Recent services include:
    Timing belt, water pump, tensioners and rollers
    Carbon cleaning and injector cleaning (Cam follower done at same time)
    All 4 injection coils replaced (F revision, by dealer)
    Oil changes at least every 5k and never had any oil consumption issues
    I have still been experiencing acceleration misfire shudder issues. If I'm on the highway and use the slap stick to keep it in 5th gear and get it up to 3k rpms and punch the gas I get repeated misfires. I wasn't getting any codes so I took it back to the dealership and had them replace the ignition coils again. After having it for almost two days... they too could not get any codes thrown and ensured me that the ignition coils were not the issue. All this was free of charge and they asked if I wanted them to diagnose further and I said no way. Knowing they would charge me for something they probably couldn't resolve considering they initially thought the car just needed a carbon cleaning. Other than the services I have already completed, any ideas what else I could look in to?
    Apr 24 2016
    California
    You didn't mention it, but did you change the plugs and gap them correctly? Sounds like it's misfiring under heavy load which would lead me to believe it's fuel or spark related.
    2005.5 A4Q 2.0T 6MT JHM 2+, Autotech internals, CTS front mount, GFB DV+, 034 Street Density mounts + snub, H&R coilovers, B7 Recaros, Phil's V4's, maybe a k04 soon?
    Mar 02 2016
    Los Angeles, CA
    If the dealership has been replacing the coil packs wouldn't that entail new plugs and they should know the gaps? I'm leaning towards fuel. Any ideas?
    Jun 17 2013
    jersey city nj
    They dont have to the plugs to change the coil paks. So there is no reason for them to check the gaps if they dont remove plugs unfortunately.
    Sep 11 2016
    West Hartford Ct
    Could be an O2 sensor. Just changed mine at 93k after misfires under load. It was triggering the check engine electrical system light so I downloaded the Dash Command App (about $19). The App allows you to check fault codes and monitor the O2 sensor via a wireless ODBII connection dongle ($12 on Amazon). The fault code indicated a faulty O2 sensor.
    Plenty of info on the webs how to monitor the O2 sensor to verify it is faulty - mine clearly was. So I ordered a new sensor ($100) online an fitted it using a borrowed O2 sensor removal tool from Autozone. The job took about an hour.
    Veteran Member Three Rings Low and Behold's Avatar
    Feb 21 2015
    Rip City
    Sounds fuel related to me. Have you checked your cam follower?
    Casey | @cshore | B7 A4 Avant 2.0T | B8 Q5 2.0T
    Apr 24 2016
    California
    Quote Originally Posted by Low and Behold View Post
    OP mentioned cam follower was changed. Fuel he'd be likely to see a code, no?
    Oct 24 2015
    Perth, WA
    Scan your car mate. It will help.
    My respray thread
    Nov 07 2015
    2004 Jeep Wrangler Rubicon, 94 Z28
    Pennsylvania
    May just be plug blow out as well, Id swap in step colder plugs if your stage 1 or higher
    2006 A4 6MT - JHM Stage 2 93 Oct flash | Cam Follower Conversion | JHM HFC | JHM Downpipe | B6 S4 Exhaust | JHM HPFP Internals | JHM Small Core FMIC | 034 RSB | Sway Bar Endlinks
    Feb 21 2015
    Rip City
    Quote Originally Posted by RakkCity View Post
    Gah I suck at reading.
    He wouldn't necessarily get a code. You can blow straight through a cam follower without getting a code (and fuel pressure would definitely be down). Scanning would tell us the most.
    Senior Member Three Rings engineerjet's Avatar
    Aug 02 2013
    Most has already been covered, check plug gaps, cam follower, coils.
    From personal experience I've experienced most of them and then some. When it comes to misfires, maybe also see if your valves need a cleaning, and possibly your in tank fuel pump may be on its way out.
    I replaced my in tank fuel pump and the misfires never came back.
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Not everything installed by the dealer is fine and dandy. Have them recheck/reseat the plugs/coils again.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Definitely check all the plugs and gaps ... "mind the gap"
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Plugs
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Mar 02 2016
    Los Angeles, CA
    Update -
    Changed out the spark plugs. Dealer told me they looked good and they looked like absolute shit. Swapped with OEM Bosch and made sure they were gapped correctly. Did not fix issue.
    Took the car an indie performance shop and drove with the tech to show him the issue. He hooked up the laptop and took it for a good drive and still could not get any thing to pop up in the logs. There is a metallic grinding/buzz noise that happens at the top end of the gear, which is when the "misfire" feel happens as well. We both thought that it might be the waste gate, but he inspected the waste gate and turbo and he said it looks great. Told me to wait until something breaks and that I have done all maintenance to have this car run for a long time and sent me on my way.
    Now let's introduce this metallic grinding/buzz noise - http://www.audizine.com/forum/showth...T-Rattle-Noise - I know it's tough to hear but you get the point.
    It takes about 15 mins of driving for the car to warm up before any of these symptoms start happening (i.e. what feels like misfires/shudder, and grinding noise). It happens most frequently when you slowly get the car up to speed in any gear and then 3-4 seconds before the car shifts into the next gear, you get what feels like misfires and this metallic grinding/buzz noise.
    The tech said it could be the motor mounts, but I don't understand why the car would have to be warm for those to start failing? And those most likely wouldn't cause a metallic grinding/buzz noise?
    Any idea guys? Thanks!
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    I wanna say the metal sound may be coming from your drive shaft. You'll have to put it in the air while someone is driving it to pinpoint where the noise is coming from.
    Mar 02 2016
    Los Angeles, CA
    That's what I was thinking. CV joint or the center support bearing. Does this sound right?
    Mar 02 2016
    Los Angeles, CA
    Update -
    Turns out that both the shudder and grinding noise were caused by a bad torque converter (incase anyone else is experiencing these issues). 6 months later and a good amount of $$$ the problem is fixed.
