Results 1 to 10 of 10
    Veteran Member Three Rings mkemk3's Avatar
    Oct 11 2010
    Central MA
    Driver side turbo installation
    Does anyone see a problem with me relocating my coolant return line to the side of my CHRA? Seems that the plug can be moved. I think this will give me a better path for the line.
    Avants do it better!
    Jul 20 2011
    Providence - RI
    Those lines are so shitty to deal with. I'd like to find the ****** that designed this car and punch him in the nads....
    Idk if that would work, it's probably at the high point for a reason, but I am not mechanic or engineer
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Quote Originally Posted by mkemk3 View Post
    I don't know what you mean but by god, I don't like that bottom silver crush washer. It's giving me the willies just looking at it...
    Oct 11 2010
    Central MA
    What washer are you referring to?
    Nov 05 2009
    Denver
    Under the upper banjo. I just wouldn't want it to leak when you get that thing fired up. It doesn't match the copper washer on the top ie: larger OD. Larger OD usually means larger ID, larger ID means it won't seal.
    Not saying that's the way it is, maybe you are 100% sure but I thought I'd bring to your attention as a courtesy.
    Oct 11 2010
    Central MA
    There is in fact a copper washer under there. Thanks though, the angle that I took the pic you can't see it.
    Oct 11 2010
    Central MA
    Any veterans want to weigh in?
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Never done it myself, but dont see why it wouldnt work if you want to customize the lines.
    Tials are on the sides like that.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Oct 11 2010
    Central MA
    Quote Originally Posted by zillarob View Post
    My thoughts exactly. Asked a few friends and they thought the orientation would matter. Made me second guess it.
    Nov 16 2010
    WetSide, WA
    I have never seen any reason to mod the lines and do it like that, and Ive done a few
    The ports look like they end up in the same exact area in the chra so I dont see why it would be a prob if you really want to.
