Originally Posted by
steve07588
So I unplugged the n75 valve and took it for a drive only hitting 5psi now but it don't feel any slower then when I'm hitting 20psi. Any ideas
Sent from my SM-N920V using
Audizine mobile app
If he is is getting 5 PSI of boost with the N75 disconnected, it wold seem that his waste-gate is set correctly? Since the valve seems to do something, ( boost goes up when connected) the ecu would seem to be trying to do somthing. I'm also assuming that disconnecting the N75 he means that he unplugged the cable to it?
In my mind that leaves either its not getting the correct signal to modulate or that the control loop is so far off it cant. The control loop is the signal applied based on pressure readings vs the response from the system.
Things that could go wrong:
Bad pressure data (map sensor)
Bad programming (tuned ECU)
Leak in the control lines to the N75 and or the waste gate.
A leak in the waste gate that changes the response.
A sticking waste gate that changes the response.
Confusing is that the car feels the same at 20 psi and at 5 psi.
Comments?
