Results 1 to 6 of 6
    Jan 16 2012
    Montreal/canada/Qc
    Help !! Audi A5 3.2l 2009 tic / rattle ... Timing chain ?? Video inside --
    Hi,
    I need your opinion guys , I have a 2009 A5 3.2L , 99,000 km and I've been having this Rattle / Tic noise since a couple of months (4-5) I always thought it was a loose heat shield and it didn't really bother me so I decided to leave it like that till next maintenance appointment at the garage ...
    I got it in last week for oil change and asked mechanic to check that noise as well ... turns out it's my timing chain that's loose and I have to get both upper chains replaced 2k + job , now before putting in that kind of money ... I wanted to have a second opinion to see if it might be something else like a heat shield or cat ?
    The car runs fine no CEL , at start up you can hear the rattle for a second and then the car is running good in idle ... when I reach 1200 RPM and only at 1200 RPM I hear the Rattle/Tic sound if I leave my pedal steady , if I go down to 1100RPM or up to 1300RPM it stops ...
    Rattle seems to come from under the car , here is the video.
    Thanks for the help !
    Veteran Member Three Rings Audiforumuser's Avatar
    Mar 01 2010
    2010 A4 Avant S-line
    Saskatchewan
    Woah yeah that's the timing chain. Sounds really rough. Don't wait. If it fails you're looking at an expensive mess.
    09 A5 S-line Monza Silver / Incurve IC-S10 20x10.5 / KW H.A.S.
    Jan 16 2012
    Montreal/canada/Qc
    Thanks for the reply !
    I just can't understand why isn't it make that rattle noise at idle ? If the chain was loose it should right?
    Can it be something in the exhaust line / cat?
    Veteran Member Three Rings ip428's Avatar
    Jan 01 2015
    B8.5 S4 6MT, B8/.5 A5 6MT, 996 C2 6MT
    ATL
    Get that done soon before it kabooms on ya!
    B8.5 S4 6MT - KW V3/JHM/Magnaflow, etc etc
    B8 A5 6MT, SR66 Widebody, Unitronic Stg II+, HPA K04, Etc etc - SOLD
    IG: @infamous_m0
    ACNA Member
    Mar 01 2010
    Saskatchewan
    It could be the cat but it sure sounds like the chain. If you think it's the cat, have your mechanic check that first. Cheaper than a new timing chain.
    Jan 16 2012
    Montreal/canada/Qc
    Ok thanks
