Results 1 to 3 of 3
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    B5 trans and rear end the same?
    I've got a 2002 with an 01A. B5s with 5spd should be the same, right? Maybe different ratios so I'd need to change both trans and rear end at the same time?
    There's a good deal on a V6 B5 with wrecked engine, and nice wheels. Figured if I can use the gearbox, it's worth it just for the wheels... and I'd have some spare parts.
    (mine is 1.8T - but 01A bolts to both, right?!)
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    The V6 is geared longer than the 1..8t
    Sent from my SM-N910V using Audizine mobile app
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Jul 03 2010
    1988 Merkur XR4Ti, 1986 911 Coupe, 1991 Alfa Romeo 164
    New York
    This thread will give you the answers you need...
    http://www.audizine.com/forum/showth...ssion-Swap-DIY
    But in short, you just need to swap the center diff housing from your B6 gearbox in place of the one on the B5 gearbox.
    Brad 2002 Quattro 1.8T w/ 2.8 B5 5-speed
