    Jul 07 2009
    Alexandria, VA
    allroad + Coilovers (Bilstein B16 PSS10): Control Arm Question
    All-
    Considering moving from my B8 Avant Sline springs on my allroad to Bilstein B16 PSS10 Coilovers (similar to Killerbootsman) and am trying to determine if I need to get Adjustable Upper Control Arms; I want to keep OEM suspension specs in regards to camber, etc. and not sure if the OEM Control Arms can accomodate.
    Can anyone chime in with some knowledge on this?
    And before you say ask Killerbootsman, I've already done that and he wasn't 100% sure
    Thanks in advance
    Present
    2018 S5 Sportback - Navarra Blue/Rotor Gray, Prestige
    2015 Toyota Highlander Limited Platnium - Family Car
    1978 Toyota FJ40 - Mustard
    1962 Porsche 356 - Red/Black
    Past
    2014 allroad - Monsoon Grey/Black, Premium +Bilstein PSS10, SPC Control Arms, 20" OEM RS5, Canvasback Liner, OEM Rear Window Sunshade Inserts, VAGCOM Mods
    2007 S4 Cabriolet 6MT (x2)
    Jun 29 2007
    Texas
    Pretty sure you would need new adjustable control arms.
    Too much negative camber that cannot be corrected.
    I guess it will also depend how much lower you plan to go.
    Forum Moderator Four Rings DirtD1ver's Avatar
    Feb 20 2013
    2017 Allroad, 2020 Q7
    MD
    I would tend to agree with ^ .
    Don - Forum Moderator, Audizine
    Current: 2017 Allroad Prestige Manhattan Grey
    Previous:2013 Allroad Prestige Monsoon Grey
    Apr 06 2011
    MA
    I'm on Bilstein PSS10's with SPC adjustable control arms... needed to be able to adjust camber for 20x10.5 BBS CH-Rs. I just put new rubber on, and will be headed into the shop for a professional alignment next week... camber, toe, corner balance, etc. This isn't a "chain" alignment shop. This doesn't answer your questions per se, though it gives you additional information on a similar set up.
    Also, let me add that your actual ride height will be a factor. How low do you intend to set the coilovers? This is an example of the additional factors you have to consider.
    Jul 07 2009
    Alexandria, VA
    Thanks, Zephyr7 and others.
    Planning on going 26.5" FTG so think adjustable control arms will be necessary.
    Present
    Past
