Results 1 to 19 of 19
    Jun 04 2016
    A
    TSFI B8 A4 2.0T quattro PCV replacement options
    Hi guys,
    im looking at doing stage 2 tune (or do they call it "chip") to the car. so im stocking up on the necessary ususal parts; such as Diverter valve, catch can etc.
    However, ive heard that the Audi PCV valves are crappy and should be replaced. But I hadn't heard whether there is an 'improved' or updated part.
    can anyone point me in the right direction for what I should buy?
    To satisfy the people who are vigilant with the SEARCH forum function, well I did do a search and found only one piece of info. Which is the o34 PCV replacement for OEM has caused an irregular idle for some users.
    my car currently has 38,000km (23,612mi)... should it require replacement to go into stage 2?
    Cheers
    May 24 2007
    PA
    You don't need a diverter valve or catch can for a stage 2. Just a high flow cat and a matching tune.
    I just replaced my leaking PCV valve with a factory replacement for around $80 bucks from the dealer. Running great with GIAC stage 2 tune and 034 high flow cat.
    Established Member Two Rings RG4's Avatar
    Jul 25 2016
    NJ/NC
    You don't NEED an upgraded DV for stage II, but if you haven't replaced the factory one it's probably a good bit of preventative maintenance to do it. Why not go with the GFB DV+. $130 I believe. Stock would be fine though
    2010 A4 2.0T Quartz Grey
    APR Stage II | APR Cast Downpipe | AWE Touring Exhaust | aFe Dry Flow | ECS Turbo Inlet | GFB DV+
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Just get the latest revision of the factory PCV unit, about $140.
    Jun 04 2016
    A
    Quote Originally Posted by s4baby View Post
    Quote Originally Posted by RG4 View Post
    Quote Originally Posted by S4'ed View Post
    Thanks guys for your prompt and helpful responses.
    Yeah I heard the divertervalve isn't crucial but it should be replaced for longevity.
    Yes I am looking at the GFB one, which is popular. I am wondering, I am to replace it myself, will it throw an engine error code? or is it just bolt on and no issues?
    My remaining questions are, will the hiflow cat increase the exhaust tone? and what is the part number and/or link to the updated PCV? I couldn't find it on ECS tuning.
    Thanks heaps
    Jun 04 2016
    A
    anyone ? im looking to purchase these parts in the next day or so from USA. so if you can provide me with the updated/revised PCV, that would be great.
    As I don't see the word or comment; 'revised' on any of the websites.
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Quote Originally Posted by doublespeeded View Post
    Call the Audi dealer and ask them for the pet number for the most recent PCV for your car, they'll be happy to give it to you.
    Sent from the Pedal Responce boardroom
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Jun 04 2016
    A
    Quote Originally Posted by Project Quattro View Post
    Ok so there are no aftermarket options such as GFB or Forge etc etc?
    May 24 2007
    PA
    I don't believe there are aftermarket PCV options unless you get a catch can kit. As we said, just go with a factory replacement PCV and call it a day.
    Jan 03 2013
    Baltimore
    Thanks heaps
    The GFB is a direct replacement which uses some parts from the factory DV. Instructions with the unit are self explanatory. If you do everything correctly, there should be no error codes. I ran mine before I had a tune without issue and it works great now with APR Stage II. Good luck.
    Jun 04 2016
    A
    Ok that makes sense now.
    I may just buy a catchcan kit which comes with their own PCV and this way I can kill 2 birds with 1 stone. (catch can and a different PCV)
    cheers
    Jun 04 2016
    A
    I thought id ask one last question before I proceed.
    If I am to install a catchcan kit (which includes its own PCV) myself, is there any chances of throwing an engine code light?
    Thanks & regards,
    Jun 04 2016
    A
    I thought id update myself on this one... lol PCV valve replacement does not throw any codes.
    Im wondering, if anyone can shed some light in experience.
    how differently does a piston style DV effect on driving in comparison to a diaphragm type OEM DV (that hasn't got any issues)???
    obviously if the diaphragm tears, then there's all sorts of issues and compromise in performance... but im wondering if there are any noticeable difference with a perfectly operative Piston DV vs Perfectly operative Diaphragm type DV?
    cheers.
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    The PCV valve do you really need to go to the dealer for a update of software if you install the updated version?.
    Veteran Member Three Rings Jacon's Avatar
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    Quote Originally Posted by ducati View Post
    yes
    My current rides...
    Audi
    Jetta
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    It's hard to get specifics from Audi, but this is my understanding of the operation of the stage1 fix. The new PCV results in a different vacuum/pressure level in the crankcase to alleviate the tendency for blowby. This new condition may cause a sensor to throw a code, which is why a software update is needed. It isn't clear if this will always happen, only happen under certain driving conditions, or perhaps never happen.
    2011 A4 Avant
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    Quote Originally Posted by jfo View Post
    I was told the only thing the update did was change the parameters to check oil level more often, that way they could see oil level over a period of time that way they just aren't replacing engines for anyone else who says they have oil consumption issues.
    Junior Member Two Rings yo vanilla's Avatar
    Nov 22 2014
    Appleton, WI
    Regarding codes, I replaced my pcv last weekend and got a P2626 code after a day or two ('13 A4 allroad). At first I noticed the hardware may not have been tightened fully (possibly presenting a leak); after re-tightening and clearing the code it came back two days later. Moving on to more troubleshooting...
    2013 allroad
    Jul 16 2018
    Atlanta
    P2626
    O2 Sensor Pumping Current Trim Circuit/Open (Bank 1 Sensor 1)
    O2S signal front > 4.81 V
    Looks more like an electrical circuit issue with the lambda sensor (front O2 sensor) rather than anything to do with the fine oil separator (aka PCV).
    2009 A4 Avant 2.0T quattro Prestige, 270k miles
