Results 1 to 12 of 12
    Jan 13 2014
    nyc
    Halogen bulb to 55w 6000k h7 led conversion?
    Has anyone done this and experienced any errors?
    These dont need to be canbus bulbs right? Just need the bulb and swap?
    And to the search nazi, yes i searched....only found hid conversion and xenon conversion threads. Suck it
    Senior Member Two Rings ChicagoDave's Avatar
    Oct 21 2015
    Chicagoland, USA
    Quote Originally Posted by nycaudi View Post
    I'm going to resurrect this thread, if I may. I'm looking to do the same and also haven't found anything searching... Swap the standard headlight bulbs in my B8 Avant from Halogen to LED.
    Anyone have any experience with this? I'm not as concerned about errors, as I can code them out.
    Seem to be many threads on LED fogs, but not LED headlights.
    Thanks in advance everyone!
    2012 A4 Avant - Brilliant Black :: Zisa LED Lighting :: Awesome Floor Mats :: Warning Triangle :: Total Newbie
    Retired - 2002 VW Passat GLX w/ 4Motion :: 14 Years and 202,000 miles
    Retired - 1995 Chevy Impala SS :: 5.7L LT1 V8 :: Dark Cherry Metallic :: Fell apart at 98,000 miles
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Quote Originally Posted by ChicagoDave View Post
    its a direct bulb replacement. im running 25 dollar fanless LED bulbs on my other car for headlights. im never going back to halogens.
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Oct 21 2015
    Chicagoland, USA
    Quote Originally Posted by JeriQo View Post
    Excellent, I knew there had to be someone! Which bulbs are you running?
    And...did the bulbs have any wiring tails or cable connectors? How did you get them in the headlight housing?
    Jul 08 2015
    im running H4s on my mazda. H11 on the b8 fogs. yours should be H7
    here you go man. should be plug and play
    https://www.ebay.com/itm/2pcs-H7-COB...paVYf0&vxp=mtr
    Oct 21 2015
    Chicagoland, USA
    Good to know, thank you. What did you do with the cables and balast-thing? How did you get the rear caps on the headlight assemblies back on?
    Jul 08 2015
    duct tape it or velcro ballast in place.
    youll see it man its pretty simple.
    Oct 21 2015
    Chicagoland, USA
    Appreciate the info and help. I'll update the thread when this happens.
    Oct 21 2015
    Chicagoland, USA
    Updating this thread...!
    I took a calculated gamble and picked these up since the reviews on EBay and elsewhere were good:
    https://www.ebay.com/itm/272108383597
    LASFIT H7 LED Headlight Bulb Conversion Kit High Low Beam Fog Lamp 6000K White
    Price was right, too. I purposely went with a bulb with lower light output to be closer to the stock output (and to not blind anyone.) Install was easy. I did end up taking the entire headlight assembly out (four screws, very easy), which made it easier to insert and arrange the bulbs. I probably wouldn't have had to if I didn't have gorilla sized hands. No ballasts on these either which is a nice bonus.
    The light output is fantastic. 3800 lumens per bulb which is plenty. Still VERY bright, I could see light reflecting off road signs from much farther way. And the white light is nice, crisp, and no lines. The fans are almost silent, too.
    So, pretty good a couple days in. I'll update if anything changes.
    Jul 08 2015
    theres no need to spend over $50 bucks on bulbs when the ebay ones work the exact same or better for $30.
    ive had my fanless leds for 3 years now even running as DRLSs and still lights the same as day 1
    Mar 31 2014
    Seattle WA
    I just ordered a pair off Amazon for the same price, any issues with codes or flickering?
    Oct 21 2015
    Chicagoland, USA
    Quote Originally Posted by anfdnguyen View Post
    It's been a month and they have been great. Granted, only a month, but I'm very happy with them. No flickering. Clean white light. No complaints from other drivers. Can't say if there was errors because I had coded out all bulb errors a couple years ago with VCDS when I swapped out my reverse lights. The packaging was clean and professional.
    Maybe they are an "off" brand but the product, packaging, and service have been excellent.
    Update this thread when you get them. I'd love to hear how it goes!
    Dave
