[QUOTE=Chard;12090508]Hi, I didn't get a notification that I got a PM, sorry about that.
I don't know the exact mileage on the kit, however the car itself only had 40k on it before it was removed, so I'd say about half or less of those miles were with the Stage 3. Functionality-wise, it was working perfectly before I removed it, so I assume it is in perfect working order. Turbos last much longer than 10 years with constant use so time is not the issue. The fact that the mileage is low would take precedence.
I totally understand where you coming from Chard.However,turbos can last much longer than 10 years "if" they WERE NOT being abused.Also,were you the ORIGINAL purchaser of the APR turbo kit Chard? Now,I know you want to sell it as a complete kit.However,some of the things will not work with my 2005 B6 A4 1.8T USP (engine code-AMB).Im sure the Exhaust manifold,the high flow cat and turbo can be used on my car but everything else won't.Such as (ECU & INJECTORS).If by any chance you change your mind and willing to sell those items separate (exhaust manifold,high flow cat,turbo & lines),Im willing to buy them from you.It doesn't have to be now but "maybe" a month or a month and a half from now.And of course,"if" you still have it and don't get to sell it within that time frame.
