Results 1 to 7 of 7
    Established Member Two Rings JordanBetch's Avatar
    Jun 22 2015
    St. Charles, Missouri
    HELP! Massive coolant leak
    Was just driving along last night when I suddenly lost ALL of my coolant in about a half mile of driving. Got under the car and flushed some water through. It looks like a busted seal, but to what? Please watch the video and let me know what y'all think!
    Established Member Two Rings big_jerm's Avatar
    Dec 04 2012
    Massachusetts
    that "bushing" is the snub mount. there isn't a seal on it. I would start by pulling the front end off. You'll actually be able to see everything and it isn't hard at all. Then you can try to find the leak. my guess is a radiator hose blew? there's a lot that could have let go up there tho. definitely pull the front lock carrier off. Look up motor pull diy and follow that till you get it off if you are unfamiliar with pulling it. Good luck!
    Silver 2000 S4: UUC Catback w/o muffler. Lowered on H&R's. Independent fogs & rear fog mod. App Radio touch screen deck. 100W amp and sub.
    Veteran Member Four Rings Turbo Nerd's Avatar
    May 12 2009
    B5 A4, B5 S4, C5 Allroad, C5 A6
    Detroit Metro Area
    I'm going to say cracked thermostat housing.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    ^^ That would be my 1st guess also.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Aug 24 2014
    Newport Beach, CA
    What they said, almost positive it's the thermostat housing. This is the time to make sure you install a metal housing, also if you haven't done the timing belt I'd recommend doing all related timing belt components now while you're in there.
    2024 M3 Comp xDrive
    Veteran Member Three Rings insomniacxp1's Avatar
    May 10 2010
    01.5 B5 S4
    Rochester, NY
    Quote Originally Posted by zillarob View Post
    2nd this ^
    Rip that front end off quick!
    01.5 Imola S4. Stage 3 F21's/To much to list
    Veteran Member Four Rings A U D I's Avatar
    Nov 13 2012
    Chicago
    Water pumps can leak out like that. You can take off you timing covers to see if it's wet in there. If it is, then that's probably the problem. Then the front comes off.
