I spent much of the day trying to clamp the Oetiker Ear Clamp onto the boot of the Inner Tie Rod. I could have completed the driver side today, but this clamp really came in the way. I don't want to resort to zip ties---because vulnerability to the elements. I can use hose clamps (built in screw), but still find the Oetiker Ear Clamps better suited for this application--it just works and has a virtually worry-free guarantee. I feel my space is not so constrained, thanks to no strut / upper control arms, and plastic bracket removed. I'm using a 59mm clamp on the Driver Side (purchased from AudiUSAParts), and though the clamp fits around the boot, for some reason I can't get the clamp to click into the next tooth. I cleaned off the vasoline I applied earlier and the Rein-branded Boot (purchased from FCP Euro) is the same exact thing as OEM (unless there are minute differences thickness, I haven't checked).
If I want to use the Oetiker Ear Clamps, should I tried a slightly larger sized-clamp (i.e. 60 or 61mm?)
Makes me wonder what the passenger side will turn out to be. The passenger side happens to use a 67mm clamp.
Here in NY, its hard to find hardware shops carrying these type of clamps; some don't even know what an Oetiker / Ear Clamp is.
Thanks
