Results 1 to 18 of 18
    Veteran Member Three Rings HamidsVikes's Avatar
    Jan 10 2008
    Vancouver, BC
    advice needed ... air suspension
    Hi
    I am in the market for a S6 or S7.
    The S6 is equipped with the factory air suspension...
    my question is...
    how much control do you have over the desired height?
    What is the height range?
    I like to have my cars low ... so not sure if this option route is the way to go, or just get a non air suspension (S7) and put in coils.
    couple of other factors...
    The S6 has heads up display, and massage seats..
    its a year newer, with half the millage (25000 km)..
    they are both same price...
    so leaning more towards the S6...
    but I think the answer to the question above will be the deciding factor!
    Nov 27 2012
    Houston/Texas
    Both have air suspension.
    Sent from my mobile
    2016 S6 | Prestige | Daytona Grey Metallic (APR Stage 1 ECU/TCU, AWE Exhaust, Eurocode Sways and Links)
    Registered User Two Rings
    Apr 26 2016
    Houston, TX
    You can buy a lowering module device and tie that into the factory air suspension that will allow you to control the exact height that you are looking for. It will allow you lower it a fair amount. You will still have use of all the different drive select controls from the MMI as well. Here is an S6 we finished up today with a Cete Module from Germany.
    . This is on Dynamic mode lowered about 20 mm lower than stock dynamic height.
    This is comfort mode with the suspension about 8 mm higher than stock height. Same car but different wheels.
    If you have any questions or would like to place an order please feel free to message me or call.
    Jan 10 2008
    Vancouver, BC
    Quote Originally Posted by Webtoker View Post
    Sent from my mobile
    I know I know...
    the one that I was looking at (S7) did not have that option.
    - - - Updated - - -
    Quote Originally Posted by Aadel@EL1TE View Post
    This is very helpful... Thank you
    can you also tell me what the cost for this is (ball park)?
    Feb 11 2013
    C7 S6
    North San Diego
    Quote Originally Posted by HamidsVikes View Post
    I know I know...
    the s6/7 is only available with air suspension, only the rs7 had the option for air suspension or dynamic package (springs/shocks)
    JOEY | '10.5 STi | '13 S6
    Cete | EuroCode | HRE | AWE | Deval | BFI | 034 Motorsports
    Nov 27 2012
    Houston/Texas
    Quote Originally Posted by JoeGie View Post
    That was my understanding as well.
    Sent from my mobile
    Apr 26 2016
    Houston, TX
    I know I know...
    - - - Updated - - -
    The module is about 1100 USD, plus install which is relatively simple.
    Senior Member Three Rings Liquidsystm's Avatar
    Apr 30 2012
    SF/CA
    S6/S7 only come in air suspension. Best and fairly cost effective way I lowered mine is with air suspension links. It cost about $100 USD and take about 45 mins to install. You still have use of all the MMI suspension settings with lowering/raising. I also bought adjustable control arms to correct the camber and had my front fender rolled because I am sitting so low. All this is still cheaper than buying an H&R module.
    This is sitting on 21's, with my stock 20's it sits slightly lower.
    14' S7
    Phantom Black Pearl | 21x10.5 ADV.1 Wheels ADV10 M.V2 CS | APR Stage 1 | AWE V2 S-FLO Carbon Air Intake | Milltek Non-Res Exhaust | Airmatic Lowering Links | Eurocode Stabilizer Bars | SPC Control Arms | Flat Bottom Wheel | Black Optics | Carbon Inlay | Xpel
    19' AMG C63 Coupe
    Obsidian Black Metallic | AMG Sports Exhaust | Night Package
    IG: gaberoonie
    Jan 10 2008
    Vancouver, BC
    That's so odd..
    I thought that too previously...
    but I asked the sales man at Audi dealership about this particular S7 and he said it did not have it!.
    I would have assumed that the sales guy would know this!
    I decided to pull the trigger on the S6 .. newer.. more options, less millage.. and it will look great beside the RS4!
    Jan 10 2008
    Vancouver, BC
    Quote Originally Posted by Liquidsystm View Post
    man.. now your making me regret my choice of going with the S6... lol
    yours looks sick!
    how much lower does the link get you than stock dynamic mode?
    Nov 27 2012
    Houston/Texas
    That's so odd..
    The sales guys often know less than the customer. I bet he had more of an incentive to push the S6.
    Sent from my mobile
    Active Member One Ring Mag559(S7)'s Avatar
    Aug 06 2016
    2018 Mercedes AMG C63s
    Fresno ca
    I had mine lowered though the dealer using their software OTIS for $150.00
    Aug 06 2016
    Fresno ca
    Here's another one on dynamic.
    Apr 30 2012
    SF/CA
    yours looks sick!
    Lol thanks. I've seen some dope S6's out there, so it's all on how you build yours. The links will adjust to go lower, but I don't do the hard parked thing, I just wanted to go as low as possible in dynamic mode running a 21x10.5 wheels without rubbing. I only drive my car in dynamic mode, so it's a bit harsh with a 30 profile, but bareable. With my stock 20's with a stock 35 profile, the tire itself is tucked, but you'll have to run some camber for it not to rub.
    I had my car even lower than this before which caused the tire to rub against the air cable which then punctured my air line and caused that particular corner of the car to air out. They had to put a repair patch kit on it, so as an fyi, something to consider relocating if you go that low.
    14' S7
    19' AMG C63 Coupe
    IG: gaberoonie
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    ...but I asked the sales man at Audi dealership about this particular S7 and he said it did not have it!...
    He was mistaken.
    Enjoy the new ride!
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    Sent from my mobile
    not ALWAYS true but usually the case
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Nov 27 2012
    Houston/Texas
    Quote Originally Posted by richib86 View Post
    Agreed :-)
    Sent from my mobile
    Nov 05 2006
    Fair Lawn
    Agreed :-)
    Sent from my mobile
    i constantly have to educate my coworkers
