Results 1 to 12 of 12
    Veteran Member Three Rings Trent212's Avatar
    Sep 10 2015
    AL
    112 octane, anyone used it in our cars?
    My buddy has some leaded 112, and I am wondering if i mixed it in with some 93 if I would have any issues running it.
    The Camaro didn't like running it and his oil temps started to climb with it.
    2018 TT RS - Nogaro Blue | CF Inlays | Black Optic | Design Selection Interior | Red Calipers | Technology Package
    APR E85, Intercooler, Inlet, And intake
    TVS Stage 3 TCU tune
    SRM TB Inlet
    SRM GTX3582
    SRM/Eurocode fuel system
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I would not! Your car though.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Three Rings KnewJack's Avatar
    Apr 28 2016
    Leaded is a no go with cat converters.
    Sep 10 2015
    AL
    I was leaning on the same thing, but there is always someone with more knowledge on any given subject than me, so always worth asking.
    SRM TB Inlet
    SRM GTX3582
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    I wouldn't bother if you still have your cats in. But a couple gallons will be fine if you don't have access to any other gas. Do you know what brand it is? Are you sure it's 112 motor octane?
    Fwiw, I have used about 6 gallons of 104 octane leaded turbo blue in my car on apr's 104 map. I do not have cats. My car ran really well on that gas. This motor really loves octane.
    That said, look into FUSE racing fuels. Super high quality and they make an unleaded 110 octane that a lot of guys around my area use. I'm actually picking some of that stuff up tomorrow to prep for my next track outing. Does not lose stability when exposed to light either. Hopefully a shop around you carries it.
    Sep 10 2015
    AL
    Quote Originally Posted by mrmomo313 View Post
    Running test pipes and let me know how the FUSE works, I might have to snag some.
    I think I will just stay with my blend until i can get a custom file from SMS for 109. Don't want any issues with the 1/2 mile stuff this weekend!
    SRM TB Inlet
    SRM GTX3582
    Jan 04 2013
    Phoenix, az
    Torco & VP both have 108/109 octane unleaded fuels. No need to go to 112 leaded, not sure there is any advantage that far over a 104 tune.
    Oct 27 2010
    Michigan
    Quote Originally Posted by Trent212 View Post
    Was on tatapalk so didn't see mod list. You'll be fine on test pipes but yes I'm not sure how SMS maps work. APR and GIAC tunes can run high octane just fine.
    Will definitely report back on that fuel though. Hoping to make some 1/4 mile passes this wed on it.
    Established Member Two Rings tec15's Avatar
    Jul 14 2015
    if my ECU has a standard APR programming, how much faster would an S5 really be in a 1/4 mile run on 100+ octane?
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by tec15 View Post
    http://www.audizine.com/forum/showth...ag-Strip-Times
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Jan 04 2013
    Phoenix, az
    what octane tune do you have? Did you get a fully loaded tune package? Like I have stock, 91, 93 and 104 tunes in mine.
    If you have a 93 tune and run 100 you might get a bit more hp, depending on the conditions but its not going to be huge.
    Oct 27 2010
    Michigan
    You don't have program switching so unless you get the 100 map put on your car, it's not going to do that much for you. You'll probably hit APR's ignition targets for the 93 map if conditions are good with the 100 octane gas. Should run a strong time just not nearly as fast as an APR car on the 100 map, as that map makes more timing than the pump file.
    OP, waiting on new plugs before I test the 110 gas...
