Results 1 to 3 of 3
    Registered User Four Rings Phil@USP's Avatar
    Sep 18 2012
    Coral Springs, FL
    USP Motorsports | EXCLUSIVE **ARP 2.0TSI Crank Pulley Bolt**
    Veteran Member Three Rings jachien's Avatar
    Nov 12 2012
    Cerritos CA
    What's wrong with the oem crank pulley bolt?
    2013 B8.5 S5 - Dual Pulley 189mm/57mm. EPL E85 Dual Pulley/DSG flash. Autotech HPFP. APR B8 Heat Exchanger. Injen Intake. Deleted Mufflers. 034 Street Motor Mounts. 034 Driveline Mount Inserts. KW HAS + H&R F:20mm/R:25mm wheel spacers. S6 Brake Conversion
    Sep 18 2012
    Coral Springs, FL
    Quote Originally Posted by jachien View Post
    The factory bolt is a stretch bolt. So once its been removed it cannot be reused. Also for any type of motorsports applications the grade of an ARP bolt is more suitable.
