Results 1 to 4 of 4
    May 01 2013
    Electric Fan Kits.
    Just wanted to know if anyone is running EFK for a 4.2 A6? If so what size? I believing timing belt due and one of those since I'm there.
    TIA
    Established Member Two Rings CAL4.2's Avatar
    May 21 2014
    2001 Mustang GT 5-Speed
    EFKs are factory on the US A6 C5 4.2's. I know because mine failed recently and had to be replaced :)
    Current:
    FOR SALE '02 Audi A6 4.2Q Tip (98k mi) Sport & Prem Packs, 18z 6Piston Fr Brakes|Bilstein|RS6 18x8 ET35|A/S 245/40|Gruvenparts)
    '01 Ford Mustang GT 5-Speed (135k miles):Coilovers & stuff (Bilstein|Stoptech|Porterfield|Maximum Motorsports|FordRacing|Michelin PSS)
    '03 Honda S2000:Totaled
    '05 Honda S2000:Sold
    May 01 2013
    What EFK kit did you order and what was the size?
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    Quote Originally Posted by CAL4.2 View Post
    Sort of true. Yes there are two efks on a stock c5 for the aux fan and for the ac fan. If you are refering to an efk, then i assume you want to replace your viscous belt driven with an efk?
    If so you have two options from my previous research. Replace the viscous fan clutch with the rs6 equivalent pulley. Or replace the snub mount brackets from a d3 platform with respective pulleys. Google the serp belt layouts of a c5 rs6 and d3 a8.
