Results 1 to 13 of 13
Thread: Underboost Code
    Sep 06 2012
    Birmingham AL
    Underboost Code
    What are all the possible causes of an underboost code? I've got an intermittent CEL showing for underboost condition and I want to determine what is causing it. I had a string of codes relating to the intake and EVAP purge valve along with the underboost code originally. I replaced the EVAP purge valve and intake manifold and cleared codes, but the underboost code remains. Like I said it is intermittent and really only shows up under heavy load uphill, car feels like it is still boosting under normal conditions.
    I checked the wastegate arm and there is a little play back and forth perpendicular to the engine, but none forwards or backwards parallel to the engine. Is my wastegate loose and definitely to blame? Could it be some sort of a sensor or vacuum leak causing the issue?
    I am looking to fix the car as cheaply as possible and then sell it due to all the issues I've been having and I'm starting a new job that will require 150 mi commute daily, but at the same time don't want to screw the next guy with a "band-aid" fix.
    Veteran Member Four Rings wxsgt's Avatar
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    diverted valve usually and/or clean the maf. that's what did it for me
    Sent from my SM-G920P using Tapatalk
    2010 Ibis White Audi A4 P+ l Upgrades: RS4 grill, Akebono Brakes, Debadged, Solo Werks S1 Coilovers, Targa Trophy Stickers(guaranteed 10+ HP) l
    2009 Ibis White Audi S5 Coupe | Upgrades: RS Grille |
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    Quote Originally Posted by SejRamkas View Post
    Wastegate should have no movement in any way. The only non band aid way to fix is to purchase and install a new turbo...
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by Alex1188 View Post
    +1^ new turbo for about $1K and a Saturday with friends to install it.
    Stage 1 more than you RS3
    Sep 06 2012
    Birmingham AL
    Quote Originally Posted by o1turbo30v View Post
    This is what I was afraid of. Probably end up buying a used one and throwing it on before I sell it. Yeah it won't be a brand new one, but it should last the next guy long enough to give me peace of mind if I find a lower mileage one taken off for a k04...
    Jan 13 2014
    nyc
    Youre problem doesnt seem to severe yet... y not buy the clip that secures the wastegate rid...uou might be able to get away with it. Its only 15 nucks for tje clip
    Sep 06 2012
    Birmingham AL
    Quote Originally Posted by nycaudi View Post
    What clip are you referring to? I remember reading there was some such clip for the VW platform (jetta I believe), but nothing that fit the A4 to help with this. There was a cheap fix I read about cutting the wastegate actuator rod and threading it and using a threaded adapter to take up the slack, but this is a bit too much of a band-aid fix for me. Yeah I guess you can argue so is replacing with a used turbo, but at least it wouldn't be an obvious band-aid when it fails again (because lets be honest, these wastegates are crap and it WILL fail again...).
    Jan 13 2014
    nyc
    The clips are available for the 2.0 audis...its recommended to be purchased along with the latest revision of the stock turbo. Revision S. It just snaps on to the rod/swivel area and is meant to keep things tight. Just call your local dealer and have them gove you the part number ...its like 15 bucks but you can probably f8nd it online for like 10
    Sep 06 2012
    Birmingham AL
    Riddle me this. Drove the car yesterday and this morning after it has been sitting for 2 weeks (trying to keep miles off it for selling). The car drove beautifully with no CEL at all. Car boosted as normal and drove like nothing was wrong. I've also noticed the car is more responsive with better low RPM boost when it was cold in "closed loop" mode as opposed to open loop. Typically this would point to a sensor, but is there something else the car does with boost control that changes once up to temp?
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    The CEL will come and go here. When I had this issue, I found (as most here will agree) that the CEL would be present on warmer or humid days that I really got on the throttle. The clip may work, but if you already have a gap between the housing and the wastegate, the clip won't do much to pick up the slack. I am by no means saying that it won't do anything, but it can really only do so much here.
    I will have the turbo I used to correct this issue up for sale shortly, if you're interested.
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Jan 13 2014
    nyc
    Thats how my issue started...until i got the cel permanently. Sounds like youre in the early stage still
    Sep 06 2012
    Birmingham AL
    Car definitely shows the CEL on warmer days after its been on the road a few miles. Definitely the problem based on the similar symptoms from both of you. Will be looking to pick up a used turbo soon.
    Jan 13 2014
    nyc
    Try to get s revision...thats the latest...and should come with clip already installed
