Results 1 to 17 of 17
    Sep 24 2013
    Chicago, IL
    a4 b8 avant - hotchkis f/r sway bars question
    i am getting ready to order these bars soon and i was told to also do all around end links, i am thinking of eurocode adjustable front end links and i'm not sure what to get for the rears since i haven't found a pair that are adjustable? I've hear that the non adjustable eurocode ones will make a shit load of noise is this true?
    anyone have these none adjustable eurocode ones? do you recommend them?
    thanks
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    This is a great idea to do end links while doing sway bars.
    034 Motor Sport makes a good set of links as well to check out!
    Fronts
    Click here
    Some key features.
    • Adjustable Length
    • Aurora Spherical Bearings
    • Motorsport Quality
    • Improved Steering Response, Handling, and Road Feel
    • Easy, Straightforward Installation
    • Fully Rebuildable
    Rears
    Click Here
    Some key features.
    • Billet Aluminum Construction
    • Fully Rebuildable
    I have not heard any issues with with squeaking while using these end links. We also carry that sway bar set when the time comes just let us know!
    Thanks,
    Alex
    Sep 24 2013
    Chicago, IL
    Anyone rocking the rear eurocode or 034 links that could give a review?
    Senior Member Three Rings NLPed68's Avatar
    Jan 21 2016
    1968 Chevy C10 Restomod, 1974 Bronco Crawler
    Hayden, AL
    I have the F & R EC sways and end links on mine. But I've only had them for about 300 miles. No noise at all & the handling is absolutely fantastic.
    Thanks,\
    Ed
    2012 A4 Avant... APR K04 /c APR tune, B&B catback, 034 HFC, 19" Avante Garde M510's, Bilstein B12 kit, Eurocode F&R swaybars/endlinks, Alu Kreutz, RS4'ish' Grilles, ERON rearview camera, EuroCode FMIC & plumbing, Kohlefaser Luft-Technik intake System, Ross-Tech VAGCOM, R8 coils, S-Line steering wheel /c paddle shifters, S4 F&R brakes /c drilled & slotted rotors/EBC's/stainless lines, LED taillights, Not a Mod, but WeatherTech laserfit floormats, 20% Tint, More to follow
    Sep 24 2013
    Chicago, IL
    thanks NLPed68
    Veteran Member Four Rings Dub_prime's Avatar
    Sep 10 2012
    2010 A4, 2008 Passat, 2002 GTI
    Bham AL
    I have the 034 rears on the stock bars and it all but eliminated the understeer that was present stock, well worth the money. If you do upgraded bars the rear would definitely be needed, if you have the metal front end links not so much.
    Veteran Member Three Rings ToddBrunswick's Avatar
    Dec 07 2015
    PorscheCayenne
    Culver City, CA
    I went with moog endlinks with the EC sways. No noise and solid as can be. Way cheaper too.
    Pedal Responce Consigliere
    "I have a special practice. I handle one client" -Tom Hagen
    Senior Member Two Rings ECDT's Avatar
    Jul 15 2015
    Philadelphia
    +1 for moog endlinks and I am just using a H&R rear sway bar didn't see the need for the front
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    You don't need end links, the difference will be so minute, the real noticeable change will come from the bars themselves.
    Jan 21 2016
    Hayden, AL
    ^^^ Sorry, but that's totally incorrect. The stock end links are a terribly weak link in the suspension. Plastic pieces that are meant to prevent the weight of a vehicle from pitching/yawing. You add new higher performance sways and they will most certainly fail. The moog pieces are a great non-adjustable replacement as they are at least a well built metal piece.
    Thanks,\
    Ed
    Feb 06 2012
    Allentown, PA
    Quote Originally Posted by NLPed68 View Post
    So Audi doesn't know what they are doing when they install plastic swaybar end links on every A4/5/6/7/8 with a sport package that has larger diameter swaybar then the comfort suspension? Or the fact that every S/RS4/5/6/7/8 has plastic end links? Mine must be the best plastic ones ever, 60k miles with Eibach swaybars and no issues. Metal ones are a good comfort buy but not a requirement.
    Sep 24 2013
    Chicago, IL
    very interesting point of views. thank you guys
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Although the stock swaybar links are plastic, the certainly aren't made of silly-putty, they are plenty stiff. I have the front and rear Eurcode bars on my S4, both set to full-stiff, with the stock plastic endlinks....no problems after about 20,000 miles so-far. The improvement in roll-control if you swap to the metal endlink types (no rubber bushings) will be minor, not worth the crazy cost and eventual wear-out of the metal endlinks. If you feel the need for "better" endlinks, get the metal Moog ones, with the polyureathane bushings.
    Sep 24 2013
    Chicago, IL
    Quote Originally Posted by S4'ed View Post
    very helpful Ed thanks Bud
    Jan 21 2016
    Hayden, AL
    I certainly wasn't trying to stir up a beehive here, but I have seen several of the o.e. plastic endlinks fail at the track and end a driver's day in a horrible way. Daily street driven on some curvy back roads may never fail, but bring them to a track and lets see if they hold up for a full weekend.
    Thanks,\
    Ed
    Sep 24 2013
    Chicago, IL
    its all good man, the feed back from everyone's experience and thoughts helps
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    I have EC's front/rear sways and adjustable arms as well. Having performed the install myself, I used lithium grease to lube the bushings and have yet to hear any noises from them. Having an allroad as a DD, I can tell you, it's a front end hog and has a tremendous amount of understeer; go into a corner hot and you can be guaranteed that you'll never get out. Having upgraded from the OEM bars to the ECs, the understeer I had is all but gone. This weekend, I drove a privately owned road call Maryhill Loops. The allroad performed flawlessly. I could dive into a turn, crank the front end and KNOW with conviction, the back end would come around without any hint of understeer. Now at low speeds, anything less than spirited driving, you are not going to notice much difference.
