Results 1 to 10 of 10
    Junior Member Two Rings
    Nov 06 2013
    Baltimore MD
    Question Front Bumper Alignment
    Brother's 2001 A4 front bumper will not line up on the sides where bumper meets fender. On left, it is pretty close. On right there is a 1/2 inch gap which will not close. It looks like bumper is prevented from coming up due to the headlight being in the way.
    Does anyone have experience with this? Is there a common way to re-align bumper to fender beyond the usual re-installation for service position?
    Any advice will be appreciated.
    Thanks,
    John
    2003 A4 1.8t 5 speed - my brother
    May 03 2015
    United States
    If I was there in person I can help. It's one of those feeler things but maybe check ur headlights and screws all there n tight. Also the guides? And is this aftermarket bumper coz they usually never are exact. Always shorter or some even longer.
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    Quote Originally Posted by RichLu View Post
    Any further comments on the guides? I have this exact same issue. The headlights are not interfering with the bumper and the bumper IS clicking into the guide, but it is a half inch below the fender line.
    Are the guides adjustable?
    May 03 2015
    United States
    Quote Originally Posted by Believer View Post
    Guides should be as in how it came and if it was replaced then should mount it where it was original. I taken my bumper on B off many times but the usual prob I hear is getting the space perfect between headlight and the bumper. But unless ur bumper is aftermarket I don't see why it wouldn't aline other than your guides need to be replaced
    Senior Member Two Rings RagtagXMASTER's Avatar
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    Adjust the bumper shock inner adjustment and iff needed adjust the side brakets as needed. A pic would help also. Im really fussy about my alignments so i understand the struggle.
    Veteran Member Four Rings Cgoon009's Avatar
    Mar 02 2013
    I have a garage? Do tell...
    DC
    Your guides may also be worn out.
    Eurosport Tuning at it's Finest
    Oct 24 2011
    New Jersey
    Quote Originally Posted by RagtagXMASTER View Post
    So the side brackets are adjustable? Good to know will give that a shot and if no luck i'll order new guides.
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    My 01 brackets have an adjustment area. The holes are oval to move them sligtly. I know though on some older ones they are not so you might have to drummel them out a little.
    Nov 06 2013
    Baltimore MD
    I will try adjusting the guides when I visit brother in 2 weeks and report back. And if that does not work, see if guides are worn out. It is good to see I am not the only one with this problem.
    Thanks for the advice.
    John
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    Fender bumper lines is the hardest to get perfect in my opinion if you really car about fitment.
