Results 1 to 9 of 9
    May 18 2011
    Grand Rapids MI
    Possible engine replacement
    Long story short I purchased a 2011 S4 with a known timing chain problem. I pulled the motor and I am weighing some options. Does anyone know if the 3.0t out of an A6 will be the same as the S4? I know the intake and exhaust are different and possibly some accessories but I could use that off the motor I have. The motors from the A6 are easily 2k cheaper. Just trying to decide if I want to replace the engine or fix it.
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    The botoom end should be exactly the same, but I would tear down the one you have and build it.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Established Member Two Rings darkstarghost's Avatar
    Feb 08 2014
    2014 Estoril blue s4
    the bottom end is shared between a large variety of models, from what i have found the a6 has different cams,chain tensioner, and pistons. This is going off of oem parts site. I'm almost 100% certain the s4 has more aggressive cams since the a6 idles a whole hell of a lot nicer than my s4. I agree with what Blownone says, tear it down and see what damage is done then go from there.
    Estoril crystal blue,APR Tune ,stainless steel clutch line, Custom Audi ring subs, BFI weighted shift knob, Passport 9500ci stealth install(in mirror),custom 1 off carbon fibre inlay blue trim, ecs kohfllufl luft intake, Stasis challenge mode exhaust, USP stainless steel brake lines, P3 multi gauge, Snow Performance Meth
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    It was my impression that the 3.0 SC engine in the A6 was somewhat detuned. in comparison to the S4. Maybe just software. Not sure though. Won't fixing it make it more valuable and better for resale?
    Dec 19 2004
    How about the motor out of a wrecked SQ5, assuming you can find one?
    2011 B8 S4 | EPL Stage 2 | KW H.A.S. | APR Stage 1 & 2 Carbonio Intake | Borla Exhaust | Eurocode Alu Kreuz | Eurocode ÜSS Stabilizer Bars and End Links | 034 Motorsport Trans Mount Insert | Spulen Rear Differential Mount | Hartman RS 4 Wheels
    May 18 2011
    Grand Rapids MI
    Pulling it apart some tonight to see if it actually jumped time or not. The only thing that makes me nervous is that it had quite a bit of oil on the center plug on the left bank. Will probably do a leak down to check for bent valves etc. Thanks for the input.
    2011 Imola Yellow Audi S4
    2016 Nardo Grey Audi RS7
    Established Member Two Rings cchase231's Avatar
    Dec 02 2014
    SE Michigan
    Do you know what caused this car to skip timing?
    Jan 28 2015
    BMW 435i Grand Coupe 2015
    Melbourne, Australia
    It would be better to see the S6 twin turbo V8 or the 4.2lt V8 from the RS4 in it!
    May 18 2011
    Grand Rapids MI
    I do not think the car skipped time as the valves do not seem to be bent after doing a leakdown. Have to pull the trans off the motor yet, however with the left upper timing chain cover off the tensioner is maxed. The car has chain rattle on start and if revved slightly, it also had cam crank sensor correlation codes. It was diagnosed by a dealer as well as an indy shop. The guy I bought it from did not want to spend the money on the repair. Also the car has 181k miles on it.
