Results 1 to 16 of 16
    Active Member One Ring brandon_morgan2's Avatar
    Feb 16 2016
    Colbert, WA
    My car has just made is past the 100,000 mile mark what should I do/expect?
    Purchased the Car in February from a local dealership with 91,xxx miles. I have since got a APR Stage 1 tune, K&N CAI, changed the oil twice with Mobil-1 Full synthetic and a Napa gold filter, and changed the Spark plugs with NGK plugs. Don't know much more then that the car was California and may have had two owners. The only problems that I have had have been with my rear drives side lock. Any other things that I should be taking care of? Thanks in advance!
    2009 Audi A4 B8 2.0T
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Quote Originally Posted by brandon_morgan2 View Post
    Kidding. It'll be fine. But you'll want to get your timing chain tensioner done ASAP (there's a thread on it if you look around) and probably a carbon cleaning also at that mileage.
    Sent from the Pedal Responce boardroom
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Senior Member Three Rings B7AudiSline's Avatar
    Jul 14 2012
    Eastern Shore,MD
    Quote Originally Posted by Project Quattro View Post
    I just spit my coffee at the screen.............
    Yeah I would say do the timing chain ASAP with all components to be on the safe side and maybe some new coilpacks, I would also change the transmission filter and differential fluid, flush the brakes lines/change the fluid.
    2012 B8 Quattro Prestige S-line/Black Optic PKG/Phantom Black Pearl/VCDS/TINTS/APR HFC W/3inch downpipe/Kohlefaser Luft-Technik Intake System/Turbo inlet hose/APR Stg 2/R8 Coil Packs/
    Luft-Technik Intercooler w/hard pipes
    RIP 2007 BB A4 2.0T Quattro Tip S-line Titanium Pgk/APR STG 2/Test Pipe/3'' Downpipe/Forge DV/K&N Drop in Filter/VAGCOM/APR Snub Mount/ECS Vent Pod Boost Gauge/CC/HOEN Fogs/LED City Lights/ECS LED Plate Lights/Tint/RIP
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    Have the rear main seal inspected. Put money aside for wheel bearings and control arm bushings. Find out how old the turbo is. Your car is still under the injector 120k warranty so find out if those were ever checked at the last intake manifold replacement. Plan for an intake manifold replacement. Chain tensioner for sure. This is all stuff likely to be needed over the next 50k.
    Deactivated Two Rings
    Dec 01 2014
    DavidhogAJ
    Philippines
    What are signs of the injectors and manifold going bad?
    Quote Originally Posted by earhythmic View Post
    I got these ones, no error and SUPER bright. The fitment chart says they should fit.
    http://www.ebay.com/itm/280846888551...%3AMEBIDX%3AIT
    Thanks, I might get this.
    Quote Originally Posted by pierreb View Post
    Sent from my Nexus 6 using Tapatalk
    2020 A4 allroad
    NH
    Manifold failure will yield a code and a CEL most of the time. Injectors can be tested via leak down. Basically if your manifold fails within the next 15k, have the dealer test your injectors while they're accessible.
    Sep 06 2012
    Birmingham AL
    Do you really want to know?... I passed 100K about 2K miles ago. Since passing 100K here is what's happened to me:
    Intake Manifold Replacement
    Turbo Wastegate loose (needs new turbo)
    Evap Purge Valve blew
    New coil packs (R8 packs, got mine on sale for like $15-20/piece).
    Keep in mind this is just parts that required replacement to keep the car running properly, not parts I "should" replace.
    Had the car since 45K miles and here is everything I've done up until the recent repairs:
    Stage 1 and 2 oil consumption (including piston replacement)
    Replaced turbo at 60K and it's going out again
    Replaced power steering hose for low speed shudder
    Replaced headlight bulbs due to one blowing
    Replaced passenger side door lock (see you already have that issue)
    Car still vibrates at hwy speed and I'm assuming control arms after taking it in multiple times during warranty period, but now don't want to pay to replace
    Now keep in mind mine is an '09 (first year of b8 model) and I have hit pretty much every widespread issue with this car, so consider this an almost complete list of things that can go wrong in addition to previously mentioned items (especially timing chain tensioner). I was fortunate enough to have most covered under CPO warranty, but the last repairs I did have not been. I have come to the conclusion to cut my losses and sell the car before I run into a situation like Project Quattro has illustrated above. Who knows, it could be a great car now that I've replaced pretty much every known issue, but I don't want to stick around and find out, and neither does my bank account...
    Senior Member Two Rings AFAndrew's Avatar
    Nov 15 2015
    St George Utah
    Quote Originally Posted by SejRamkas View Post
    Did you replace the power steering hose yourself? and where is it located?
    Feb 24 2013
    CA
    Shittttt, i have 185k on mine lol and i bought it 3 years ago with 30k haha
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Quote Originally Posted by Slick_B8 View Post
    5,000 miles a month? Are you delivering mail with that thing?
    I am at 111,000 miles today and have had no major issues. Replaced the front wheel bearings around 60K and the shocks/struts at 100K. Nothing else has failed, and after having the rear main seal replaced when an upgraded clutch was installed, I am using very little oil.
    Replaced the timing chain tensioner myself earlier this year.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Feb 24 2013
    CA
    Quote Originally Posted by blbroo View Post
    I do a daily commute of about 200 miles plus i like driving, alot, so i take alot of small trips to different place lol
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    2013 AR with 101,500 miles. CTS K04. been tuned since 45k miles. no issues yet
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    Damn, man. Where are you driving to? I live in West LA and to get to Riverside and back is only 150 miles round trip.
    - - - Updated - - -
    Quote Originally Posted by AllroadCorbin View Post
    And it has a new paint job to boot!
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Jan 15 2014
    Boston, MA
    yea its looking sexy
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    I would be weary of your stock catalytic converter if you still have it. My buddy who works at a shop has seen mutiple b8's around 100-120k miles have catalyst material start to degrade, which causes the cat to clog itself and EGT's to skyrocket which causes a whole host of issues, none if which you want any part of.
    2016 S3
    Instagram- @Thisisastickup
    Senior Member Three Rings JD23's Avatar
    Jun 12 2016
    Dallas
    Replace timing chain tensioner
