Results 1 to 3 of 3
    Veteran Member Three Rings INYAUDI's Avatar
    Feb 21 2016
    Southern New Hampshire
    Inner CV Joint grease leak
    So as I was swapping wheels I noticed a straight line splatter of yellow/brown grease on my skid plate. Inner boot/cv joint is healthy looking and clean. It appears to be forcing its way out from where the cv joint housing and output shaft flange meet. (sorry if my terminology is incorrect, you get what I mean) I go triple digit speeds very often so I'm not too surprised it finds its way out the cv joint and up the axle. I guess the questions I have are:
    1) What way would you go about refilling the grease preferably without having to remove the axle? The inner axle bolts were a PITA for me to get to line up and grab.
    2) Anybody know exactly what grease it is?
    Worst case I ask Audi for the grease info, grab some new tty axle bolts, pull it out and hope it bolts up without a fuss.
    Instagram: TonyConQuattro
    Nov 17 2014
    San Francisco, CA
    Shouldn't toy be under warranty? Make them fix/replace?
    Sent from my SM-N910V using Tapatalk
    Feb 21 2016
    I have coilovers, basically of my own doing. I remember when I bolted it up and was finishing up with my torque wrench that 1 or 2 felt like over 70Nm. This is a picture from the coilover install about 3 months ago. I noticed the leak about a month & half ago, tighten the bolts down tighter and it seemed to slow it down but doing it sketches me out. Broken bolts are my wrenching nightmare!
    Follow my build on Instagram: @towknee603
