Results 1 to 2 of 2
Thread: B7 N80 in a B6
    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    B7 N80 in a B6
    I was having difficulty getting my EVAP test to pass tonight and ended up pulling my N80, spraying it with some WD40, and then whacked it a few times on the concrete. Voila, it passed.
    However, I'm guessing I should just go ahead and replace it. Wanted to see if anyone was still running a B7 valve in their B6 and if they'd run into any issues. IIRC, the B7 valve just needs to be installed reversed and is a good bit cheaper.
    - Steve
    NKAWTG
    8V S3 Prestige | Sepang Exclusive Edition | APR Stage I HT | APR Carbon Intake | CTS Res Delete | H&R RSB 25mm | EMD 10mm/17.5mm Spacers | HomeLink Retro | Euro Aspherical Wing Mirrors | OsirUSA O-Shift EX Paddles
    Jul 17 2013
    Utah
    B7 valve works great just install backwards like you said. I install the B7 on all VW / Audi's that have that same style connector as they are so dirt cheep.
