Results 1 to 2 of 2
Thread: Jukebox Mystery
    Sep 04 2016
    atlanta
    Jukebox Mystery
    Hi - have been searching the forums but couldn't see anything specific so here goes.
    The other day I imported (engine on) a few tunes from SD1 that I had downloaded from itunes. Encountered no complications importing and the given i download full albums I had no problems with file structure, etc...
    Tonight (engine off) I imported some more tunes from SD2 (SD1 card still in). The import executed successfully but when I went into jukebox to play the music all folders were empty, not even the songs I had imported a few days ago. The mystery is when I go into settings and check memory, it shows some tracks being stored, i.e., 1% of memory, but because I can't see any tracks I can't delete anything.
    Not sure if this is a bug and I should just restart the MMI (hold menu, top right button or whatever) or this is a bug that occurs when importing the tracks with engine on / off or something.
    Anyone encounter this before?
    thanks
    Senior Member Two Rings MagillaGorilla's Avatar
    Nov 25 2015
    London Ontario
    Not sure if this helps or not but it maxes out at 4000 files.
