Results 1 to 11 of 11
    Veteran Member Four Rings Chanman94's Avatar
    Jun 09 2014
    Calgary, AB, Canada
    P2279, P0088, P0299 Error Codes
    Hey guys I was wondering if I could get some help on trying to pinpoint what my issue is. So I got a CEL a few weeks back and scanned my car, getting these error codes. I've had misfires before, and replacing the spark plugs and coilpacks within the last year fixed the issue. PCV has also been replaced in the last year when I was leaking boost.
    Right now I'm not experiencing anything out of the oridinary, I don't feel the car is losing power or leaking boost. Before when it was leaking boost it would stutter at 3000rpm and drop a bit in the RPM range before any power would be delivered, not the case this time.
    Just based on some research, I'm thinking it could be the intake manifold starting to go out. But there's no code for that, so I'm not 100% sure on it. The CEL hasn't come back since I cleared the codes. Any help would be greatly appreciated.
    Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
    Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
    Component: 2.0l R4/4V TF H16 0001
    Revision: E1H16---
    Coding: 0104010A190F0160
    Shop #: WSC 08224 016 263172
    ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
    ROD: EV_ECM20TFS0118K2907115AL.rod
    VCID: 79F3DE62F817C58AE7-802C
    8 Faults Found:
    7144 - Please Check DTC Memory in CAN Gateway (J533)
    U1008 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    5646 - Leak in Air Intake System
    P2279 00 [096] - -
    2837 - Fuel Rail/System Pressure
    P0088 00 [096] - Too High
    5671 - Boost Pressure Regulation
    P0299 00 [237] - Control Range Not Reached
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 115690 km
    Date: 2016.03.25
    Time: 04:19:33
    Engine speed: 5794.50 /min
    Normed load value: 80.4 %
    Vehicle speed: 174 km/h
    Coolant temperature: 90 ∞C
    Intake air temperature: 30 ∞C
    Ambient air pressure: 870 mbar
    Voltage terminal 30: 12.957 V
    Unlearning counter according OBD: 40
    4054 - Cylinder 1
    P0301 00 [096] - Misfire Detected
    4060 - Cylinder 3
    P0303 00 [096] - Misfire Detected
    4063 - Cylinder 4
    P0304 00 [096] - Misfire Detected
    4051 - Random/Multiple Cylinder Misfire Detected
    P0300 00 [096] - -
    Readiness: 0010 0000
    - Richard
    2017 Audi A4 Allroad - Mythos Black - 034 Dynamic+ Springs - Volk Racing TE37 Ultras
    2021 Lexus NX300 - Ultra White - BBS Evo X Wheels
    2017 Honda Civic Touring - Lunar Silver - Sold
    2018 Volkswagen Golf R - Oryx White Pearl - Sold
    RIP - 2010 Audi A4 - Monza Silver
    - Apparently not resting in peace anymore.
    Veteran Member Four Rings awdconnor's Avatar
    Jun 07 2016
    Portland, Oregon
    seems like you might need a new turbo... p0299 is usually the waste gate flapper getting stuck
    [COLOR="#808080"][FONT=System][SIZE=2]2018 Audi S4 P+ | 034 Stage 2 E85 | Airlift 3P | BBS RSii
    Jun 09 2014
    Calgary, AB, Canada
    Quote Originally Posted by Tiggy View Post
    Hmm excuse to go K04 then ;) But that comes as a surprise, because the turbo was replaced under warranty before because the waste gate flapper got stuck.
    - Richard
    Jun 07 2016
    Portland, Oregon
    Quote Originally Posted by Chanman94 View Post
    how long ago was it replaced? you could also have a torn Diverter valve. but if the turbo was replaced recently, you probably have a REV d.. check your coil packs and spark plugs. are you tuned?
    Jun 09 2014
    Calgary, AB, Canada
    It was replaced 2 years ago. Hmm I'll check the DV. Doubting it will be coil packs and spark plugs, those were replaced last year, but doesn't hurt to check them. Tuned with REVO stage 2.
    - Richard
    Jun 07 2016
    Portland, Oregon
    do you have r8 coil packs? what spark plugs do you have?
    Jun 09 2014
    Calgary, AB, Canada
    R8 Coilpacks, NGK spark plugs
    - Richard
    Jun 07 2016
    Portland, Oregon
    hmmm, i don't think its that then.
    Jun 09 2014
    Calgary, AB, Canada
    Bumping this. Anyone else able to provide some insight on this?
    - Richard
    Sep 27 2015
    OH
    P0299 00 code for me recently, replaced the dv and few hundred miles later nothing has popped back up yet
    Senior Member Two Rings TurboNate's Avatar
    May 16 2015
    El Cajon/CA/San Diego
    P0299 wouldn't come up if it was just misfires. When I got that code, I had to replace the turbo
    2009 A4 Premium+ Quattro
    APR Stage 2 | CTS Turbo High Flow Cat | Custom Intake System | AG 19x9.5 m580 w/ 10MM Spacers In Rear | RS Mesh Grill | 5% / 20% tint
    AKA: NathanMansoor
