Yeah, yeah, yeah, I know, this is the B5S4 forum. This forum gets about ten times the traffic the A6 forum gets and the cars are pretty similar electrically (and lotsa other stuff).
My problem is the turnsignals are always on even when the car is turned off. Here's my post in the C5 section replying to another guy with the same problem:
I'm having this exact problem: the turnsignals and sidemarkers are on all the time. It appears to be the turnsigs instead of the parking lights because the signal indicators in the instrument panel are on all the time. The only way to turn them off is to disconnect the battery. Since I have lotsa parts from a crashed A6 I bought a coupla years ago, I've done these things:
1. R&R hazard switch; unplugging the switch turns everything off but the turnsigs don't work then.
2. R&R headlight switch
3. R&R turnsignal switch
4. Reseated every single ground I can find.
5. Checked every fuse for continutity.
6. Reseated every relay and power bus cable.
7. Did the driver's side sunvisor thing as suggested above.
Thus far nothing has made any difference whatsoever. The car has been sitting for a little while but ran fine when it was parked and I didn't see the lights on then. I had to retime the driver's side exhaust cam (I effed it up during a timing belt change) to get the car roadworthy and now this. I did go back and check the connections under the coolant tank; no joy.
Any other suggestions before I donate the POS? I would really appreciate any new ideas. TIA
