Results 1 to 11 of 11
Thread: Accuair Problem
    Dec 08 2009
    Lisboa, Portugal
    Accuair Problem
    Hi,
    Só I have a Audi Q5 with accuair suspension, right now I got an issue, and it doesn't turn on...
    Although the accuair support is trying to help me, I had to mount the oem suspension so I can use the car... Because I had to air out the suspension to begin the diagnose..
    This situation made me think that there has to be a better way to resolve this on the road, instead of calling for a tow.
    Since some Audis have oem compressor for fill the tyres, maybe a system to pump air directly to the bags?
    Tks
    Enviado do meu iPhone usando o Tapatalk
    Registered User Three Rings Boden AutoHaus's Avatar
    Aug 11 2014
    Orange County, CA
    If you disconnect the air line from the valve block and attach a schrader valve, you can manually pump air into the bags.
    Dec 08 2009
    Lisboa, Portugal
    Tks boden, always to the rescue.
    But can you be more specific. Lol
    Aug 11 2014
    Orange County, CA
    You can connect the front airlines together with a union like this
    Same goes for the rear. Or you can do them to each individual bag
    Dec 08 2009
    Lisboa, Portugal
    Quote Originally Posted by Boden AutoHaus View Post
    Uau thank you for your help once again.
    Going to source some right now.
    Do you have any situation like this? The system just died... No lights, nothing.
    Aug 11 2014
    Orange County, CA
    Quote Originally Posted by sorcerer_69 View Post
    I would check the main fuse and all of your grounds first, and make sure all of the plugs are plugged in nice and tight.
    Dec 08 2009
    Lisboa, Portugal
    Checked the main fuse, the other two fuses, and check the relay... Changed the relay, nothing.
    Both compressors work when connected directly...
    Checked the grounds, and have continuity on all.
    Measure the positive, and 12,5 v after the main fuse...
    It's very frustrating
    Aug 11 2014
    Orange County, CA
    Could just be a fried ECU
    Dec 08 2009
    Lisboa, Portugal
    I think so... Hopefully
    Enviado do meu iPad usando o Tapatalk
    Veteran Member Four Rings wxsgt's Avatar
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    This run along with the standard compressor as a just in case thing?? Never done air before and doing research.
    2010 Ibis White Audi A4 P+ l Upgrades: RS4 grill, Akebono Brakes, Debadged, Solo Werks S1 Coilovers, Targa Trophy Stickers(guaranteed 10+ HP) l
    2009 Ibis White Audi S5 Coupe | Upgrades: RS Grille |
    Aug 11 2014
    Orange County, CA
    Quote Originally Posted by wxsgt View Post
    It would be run instead of, not alongside. So if you have an ECU issue, have to remove your management, etc then you can hook up the schrader valves to air up your bags using an outside air compressor.
