Originally Posted by
S4audi15
Anybody have an ideas?? Would love to hear any feedback before I go replace the tensioner that might not fix it and waste more money. The high pitch whistle sound can be heard when revving the car quickly in neutral. I also have a P0235 code supercharger boost sensor a circuit that goes on and off all the time. This code has been coming on and off way before I started hearing this noise, not sure if it's related.
I'm thinking the code and the issue are related...possibly boost/vacuum leak. What mods do you have? What maintenance was done when the problem first came to light?
At first I thought the whistle was belt squeal, but the way it changes pitch makes it seem more like a whistle from escaping air via a small hole. The change in pitch when you lift throttle is also an indicator to me. Can you shoot another video revving in neutral? When you do it, move the camera around the supercharger as well...don't just focus on the belt area. Make sure you move the camera around slowly while you film...may help you isolate location when the noise occurs.
There are a couple videos on youtube about belt chirp v squeal and the causes. You can troubleshoot most with water and a spray bottle.
If you think it is S/C belt related...you can remove that belt and rev the car in neutral, if the sound persists...S/C belt is not the culprit. This will also let you begin diagnosing the serpentine system in isolation.
