Results 1 to 9 of 9
Thread: P0601
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    P0601
    Edit: solution/tsb found see (current) last post with pictures of tsb info so that if there is anyone else whom needs this done you have the # but I'm assuming mine had it happen simply because it hadn't been driven enough before the warranty was up whereas most other a4's if not all have already been reprogrammed. This is only if you ARE STOCK NEVER TUNED if you tuned and it happened, well that's your fault
    Here's a link from apr's website which has the tsb release from AoA which is long winded, my pictures down below are short and sweet
    http://www.goapr.com/support/tsb/b8s...structions.pdf
    Hey there guys, so I'm on vacation currently and not having owned my new to me A4 long enough to trust it I likely brought along my Ross-Tech cable and found something that is bothering me a bit. So here's how it came on
    Wife and I had some down pouring this morning and were driving for probably 45 minutes in there, and there were some rather large puddles (unsure if it caused it but probably related) so we made a stop somewhere and I left my phone charger plugged in and possibly my satellite radio ( I use an external one for better features) and we were stopped for maybe 30-40 minutes, got back in and while we were driving short distance the EPC light came on.. Awesome news for a vacation lol. So we stopped again came back out, was still on (didn't expect it to go off) and the check engine light came on but car was running fine, so I didn't worry too much about it. Get back to the hotel and find this
    Address 01: Engine Labels: 06F-907-115-AXX.clb
    Part No SW: 8E0 910 115 B HW: 8E0 907 115 C
    Component: 2.0l R4/4V TFSI 00 0080
    Revision: --H02--- Serial number:
    Coding: 0104010A180F0120
    Shop #: WSC 06335 000 00000
    VCID: 204FE6E5F3F1394280-8074
    1 Fault Found:
    001537 - Internal Control Module
    P0601 - 001 - Memory Check Sum Error - MIL ON
    Freeze Frame:
    Fault Status: 11100001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 66776 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1398 /min
    Load: 15.7 %
    Speed: 0.0 km/h
    Temperature: 84.0°C
    Temperature: 59.0°C
    Absolute Pres.: 990.0 mbar
    Voltage: 11.938 V
    Readiness: 0000 0000
    So I do a google search which I found near no info on this but ross tech has a wiki page on it that says this
    16985/P0601/001537 - Internal Control Module: Memory Check Sum Error
    Possible Symptoms
    MIL illuminated
    Possible Causes
    Engine Control Unit (ECU) defective
    Flash ROM (used in aftermarket "chips") defective
    Low Voltage
    Possible Solutions
    Replace ECU
    Contact aftermarket chiptuner for repair of their chip
    Check and test Battery and Charging system
    Special Notes
    When found in 1.8T:
    This thread might be useful: http://forums.vwvortex.com/zerothread?id=915672
    When found in 2.0l TFSI (BPJ, BPY, BWA, BWJ, BYK), check/update Engine Control Module Software Version
    Audi A3 (8P), A4 (8E/8H) or Audi A6 (4F):
    North American Region (NAR): TSB 2017905/24-08-82
    Rest of World (RoW): Campaign 24H8 (2013846) or TPI 2012760
    Seat Altea (5P) or Leon (1P), see Campaign 24S1 (2014557).
    Skoda Octavia (1Z), see Campaign 24K5 (2014942).
    Volkswagen Models:
    Rest of World (RoW): TPI 2014494
    North American Region (NAR): TSB 2014077/01-09-18 or 24M2/O3 RVU (may be covered under warranty)
    When found in Audi V8 and V10 FSI engines see TSBs:
    Pass-Thru TSB # 24-08-31 (2017905/1)
    Audi TSB # 24-08-82 (2017905/4)
    Which then gets me very worried that my ECU just randomly shit the bed on me... So I reset the code and start the car again, logged block 004 for battery voltage and its reading fine (I'm assuming the battery voltage it reads is actually alternator output) it was around 13.5V the whole time, well at least at idle (I did a graph instead of log and was watching while driving so couldn't see exactly where it was at) saw no spikes or drops anywhere in it will I was messing throughout the whole rpm range so I pull into a parking lot, shut the car off turn on again, EPC lights back. Says this
    Control Module Part Number: 8E0 910 115 B HW: 8E0 907 115 C
    Component and/or Version: 2.0l R4/4V TFSI 00 0080
    Software Coding: 0104010A180F0120
    Work Shop Code: WSC 06335 000 00000
    1 Fault Found:
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 66801 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1272 /min
    Load: 18.0 %
    Speed: 0.0 km/h
    Temperature: 85.0°C
    Temperature: 51.0°C
    Absolute Pres.: 980.0 mbar
    Voltage: 12.573 V
    Readiness: 0010 0101
    So I clear the code, shut the car off turn it back on, no light. Shut it off turn it back on, light on, clear code try again and the light is back on immediately, do this like three more times and light is on every time now immediately (before it took two starts) Last code log is this
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 66801 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1288 /min
    Load: 13.7 %
    Speed: 0.0 km/h
    Temperature: 93.0°C
    Temperature: 50.0°C
    Voltage: 12.319 V
    Readiness: 0110 0101
    So what I noticed is that the voltage dropped each time I started (obviously) and the first code was under 12V, so I go look at the battery (since I just got the car) and I found the date code I couldn't find when I bought it, July 2010.... Car has 41k on it 2005.5, and is bare stock other than a symphony II+ radio and a K&N air filter, no tunes and it was owned by an old couple so I HIGHLY doubt they tuned it..
    Does this point to the battery being toasted to anyone else and should I start there before worrying about finding a new ECU?
    What voltage should I be seeing on block 004 to verify the alternator is working correctly?
    Any other suggestions?
    Thanks...
    PS, probably gonna head over to walmart and find a battery :/
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    Veteran Member Three Rings mgfranz's Avatar
    Apr 08 2016
    Mission Viejo, CA
    Battery check time. My bimmer had similar issues with electronics when it's battery was going bad, as little as 1/3 volt loss will cause issues with electronics. It needs to be above 13.7 volts.
    2008 Audi B7
    2003 Ford F250 XLT
    2001 Porsche Boxster
    1999 BMW 740i M-Sport GONE
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    My recent battery crap out was strange. Car was perfect for approx 10-15 min, about the time it took to get up to temp. When I believe the fans were clicking on car died. Mostly when at a stop I'm assuming the air flow while car is moving was keeping fans off (I don't know but I wud think that's how it works). It was all along the battery. It never threw a code or anything strange, just running fine and then nothing engine died car wudnt start. After it say for 30 min to 1 hour started fine and repeated the issue.
    Jul 25 2016
    new hampshire
    New battery didn't fix it, at least I feel better as my old one was bulging on the side apparently as I saw it when it came out.. Bad news is I don't think its a voltage issues as I had my wife resetting the code while I was driving, so I tried shutting the car off while moving to see if it had been fixed on its own, it recorded the fault at 14v
    Heres the new codes
    This was right after installing the new battery
    2 Faults Found:
    005634 - Power Supply Terminal 30
    P1602 - 002 - Voltage too Low - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: -40.0°C
    Absolute Pres.: 0.0 mbar
    Voltage: 0.000 V
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 66820 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1312 /min
    Load: 16.9 %
    Speed: 0.0 km/h
    Temperature: 72.0°C
    Temperature: 36.0°C
    Voltage: 12.065 V
    Address 01: DTCs cleared
    Address 03: ABS Brakes Labels: 8E0-910-517.clb
    Control Module Part Number: 8E0 910 517 C HW: 8E0 614 517 BB
    Component and/or Version: ESP8 quattro H04 0180
    Software Coding: 0004526
    VCID: 275DFDF996DFCE7AC1-8072
    2 Faults Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 5
    Reset counter: 39
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0222
    Hex Value: 0x00FF
    Hex Value: 0xFF87
    Hex Value: 0x00FF
    00493 - ESP-Sensor Unit (G419)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 40
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x1600
    Hex Value: 0x4002
    Hex Value: 0x00FF
    Hex Value: 0xFFAC
    Hex Value: 0x00FF
    This is while driving I shut it off
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 66842 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1071 /min
    Load: 23.5 %
    Speed: 65.0 km/h
    Temperature: 86.0°C
    Temperature: 33.0°C
    Voltage: 13.970 V
    And I left out the four others that were just in between all these, I don't think they matter
    Anybody know how to find TSB's? or know anything about the TSB suggested by ross tech?
    I'm thinking my ECU is going to need a re flash from the dealer?
    This really puts a fcking damper on my vacation
    Eric
    Jul 25 2016
    new hampshire
    Can anyone with a Ross-tech try and find out what their ECU's version/info is? Its under engine controller, advanced ID and looks like this
    Monday,12,September,2016,09:31:47:13018
    VCDS Version: Release 16.8.0
    Address 01: Engine
    Advanced Identification
    Serial number:
    Identification: BPG-810
    Revision: --H02---
    Date: 02.03.05
    Test stand number: 1888
    Manufacturer number: 1090
    Flash Status
    Programming Attempts: 0
    Successful Attempts: 0
    Programming Status: 00000000
    Required Conditions: 00000001
    Software
    P000
    A4.8.3
    Misc.
    Hardware number: 8E0 907 115 C
    Car Info
    Chassis Number: WAUDF68E95A515662
    VCDS Info:
    Readiness: 06F-907-115-AXX.crd
    It would be very helpful in me determining my version to see if I missed out on a recall or something and for me to communicate with the dealer, I'm hoping that a reprogramming from them will correct it. Thanks very much guys.
    Edited with proper info
    Eric
    Jul 25 2016
    new hampshire
    No one has any info in regards to this happening with the car never being tuned? or where I can find TSB's? When I just put my info into AOA it said there were no TSB's or Recalls for the car in the last 15 years... I am sending them an email to see what they tell me
    Eric
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by pezgoon View Post
    If you didn't clear codes after swapping the battery, you will see a lot of "Power Supply Terminal 30" codes in several modules. I see it all the time after I've even disconnected the battery. That doesn't help with your checksum error. but it explains a lot of stuff in that post right after the battery.
    I'd be happy to VCDS my ECU, but mine is chipped so I don't think I have what you need.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Jul 25 2016
    new hampshire
    Okay I figured all those were simply because I had disconnected the battery thanks for the info, ya I would like someones who hasn't been chipped, I just remembered that I needed that info and I had my cable plugged into a car earlier today helping another AZer, should've looked while it was plugged in dammit!
    Eric
    Jul 25 2016
    new hampshire
    P0601
    Alright so some news on this issue, there was/is a tsb for it, tsb 2011732 sadly because I'm out of warranty it is nothing more than information but it does say no affect on driveAbility so I have no worries continuing ignoring it for now :) they did try to tell me that normally it happens with a tune and I told them mine has never been tuned and that my mothers car showed reprogramming and hers has never been tuned (mine showed none) as they didn't really wanna look into the tsb's as they kept saying that code wouldn't have one.
    Here's the sheets.
    So there is an update and I'm going to try and convince one of the dealers around me to lower the price or do it for free so we will see what happens
    Here's a link to a different version of the tsb released for AoA from apr's website
    Eric
