Originally Posted by
vtraudt
Decided to do a timing belt service now instead of later.
Cam sprockets and crank TDC perfect.
But block 093/3 and 093/4 still show -5 and plus 2 (was -8 and zero).
I did NOT verify cam chain.
With cam sprocket (exhaust cam) dead on, and blocks 90/91/92 showing zero or +/- 1, does the -8/0 or now -5/2 mean that bank 1 cam chain is off by 1 link?
Is the phase spread (of 7 or 8 total) indicative of a chain link?
Or is the cam chain tensioner on bank one not tensioning the chain enough? (no obviouss chain clatter noticeable though).
The ECU only has crank position (very precise) and intake cam position (one impulse per revolution).
Still not clear what the values block 90-93 really MEAN and where the measurements are coming from (or are some calculated?)?
I'm not sure what you are referring to when you talk about sprocket (exhaust cam) dead on, and blocks 90/91/92 showing zero or +/- 1, does the -8/0 or now -5/2. I would verify by the firing order starting from cylinder no. 1 is @ TDC and then throughout the firing order. Guess to do this right, you need to put a dial indicator on the intake valve/cam, crap, not sure on OHC cars :( and then watch the crank position. I guess you could get a sturdy rod and put it into the spark plug hole and measure the rise with a dial indicator to find TDC. You can turn the engine by hand ....slowly just in case things are off and use a compression gauge in each cylinder to verify you are on the compression stroke. Once the cylinder is on a compression stroke, put in a reliable probe that you can measure the max height of the cylinder and follow the Firing order 1-4-3-6-2-5 for the 2.7t and 2.8. Just trying to think this thing out. I"m a chevy guy and the German stuff, particularity OHC cars are very new to me :(
As far as the 90/91/92 showing zero or +/- 1, Are you getting these codes from a ECU tuner/reader? I use torque pro. I know that if you do your timing belt, you must do two full revolutions of the crankshaft to pump up the chain tensioner. In the video below, at the 52 minute mark he references what I'm talking about. I only say or ask this because your comments about the timing tensioner chain possibly off a link. Good reminder to paint the sprocket and chain links ;) I'm a little concerned about my current engine removal while I"m reading your thread. I am in the process of removing my engine and rebuilding the engine because I will have to remove the heads, cam completely and start @ ground Zero. Not sure of this process as of yet.
LMK if I can help and if this helps...or not :) , it may help others in the future who use the search fcn, there seems to be few active members on the boards :(
https://www.youtube.com/watch?v=notzLin4dVI
