Results 1 to 4 of 4
    Established Member Two Rings hex808's Avatar
    Mar 17 2014
    Tucson, AZ
    Question Sideskirts Install Assistance Needed
    Hello folks,
    Like the title says, I am looking for some help with reinstalling the sideskirts on an a7. Specifically any tips or suggestions to get the skirt over the 9 x white clips that hold it in place. Any assistance is greatly appreciated! Thank you!
    Veteran Member Four Rings durfA4's Avatar
    Jan 01 2006
    2012 A7 Stage 2, 2014 Q5 3.0T SLine, 2001 Laser Red S4
    Boston
    They are a PIA to reinstall. But work from rear toward front.
    The skirt clips in to the top portion of the white clip above the tab and then locks into place.
    I pulled the skirt up and pushed the tab down so I could get it to fully seat. It was a pain but not too bad once I figured out the trick.
    Some of the clips may be easy to remove from car and clip into the side skirt. I removed 2 under the b piller by the doors.
    Once it's clipped into place screw in the large bottom retainers.
    2012 A7 3.0t EPL Stage 2
    2014 Q5 3.0t
    2001 S4 STUKLR tuned
    Mar 17 2014
    Tucson, AZ
    Durf,
    Thanks for the advice. Worked out well and got one side done and just waiting to tackle the other side this weekend! I owe you one.
    Mar 11 2007
    Colorado Springs
    It's not easy, I had my A7 fitted with the "S" skirts this morning. I talked to the body shop tech, and they are a 2 part motion kinda thing. There are two (2) motions and angles to get the clips to hold the skirt. He says he's done a few and it takes practice. I know that's not what you wanted to hear, but that's from the horse's mouth. Good luck...
    __________________
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
