Results 1 to 2 of 2
    Veteran Member Three Rings Krusty's Avatar
    Sep 19 2012
    long beach
    Erratic Idling Engine Light Came On
    Hello,
    Have been getting some erratic idling, however I didn't think it was an issue. This morning the idling was a bit weird and after driving for a couple blocks the car turned off and after I restarted the car when I pressed the gas the car would not move or move forward weird. The engine light came on and barely made it back to my parking spot. I know this is very general, however I am wondering if any body have any ideas to what it is. I have a cheap OBD2 connector, so I will checking the car to see what kind of codes I see. Could it be the ignition packs? Any help or ideas are appreciated.
    Here are the codes:
    P012C
    P0068
    2011 sprint blue s4, EC subframe stabilizer, ECS short shifter, Euro Impulse weighted shift knob, custom air intake, RS grille, CR-15, 034 rear diff mounts/rear diff carrier mount inserts, Apikol rear diff mount insert, 10mm(f)/12mm(r), ECS strut tower brace, ECS front adjustable end links.
    Jun 20 2015
    NC
    Post the codes
