Results 1 to 26 of 26
    Veteran Member Four Rings Poodini's Avatar
    Oct 26 2015
    2016 Subaru Outback 2.5 Limited
    Fremont, NorCal
    Ecode ALU KREUZ Question for y'all!
    Was contemplating getting it for my car. I've read some of the feedback, which is positive for the most part. The COST obviously is the main factor.
    For those of you running with it, do you feel the gains in torsional stability/better handling worth the price tag?
    I'm sure most here have it along with other suspension upgrades so just getting a feel, whether I should go for it or not..Are the overall gains worth $400+install hardware.
    Any/all comments welcomed!
    Sent from my iPhone usingTapatalk
    Senior Member Three Rings burg3ngold's Avatar
    Apr 13 2016
    Washington DC Area
    Subd
    Sent from my ONE A2005 using Tapatalk
    Oct 26 2015
    Fremont, NorCal
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    I installed mine after a set of sway bars and before a drop. The biggest thing I noticed was the change in steering. It's much more crisp now and the car just feels connected to the road.
    It's a great complement to a set of sway bars. Worth the money? I'd say yes, but others might disagree. If you can find a used one you'l prob save a hundred or more.
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
    Senior Member Three Rings NLPed68's Avatar
    Jan 21 2016
    1968 Chevy C10 Restomod, 1974 Bronco Crawler
    Hayden, AL
    I obviously did a major suspension upgrade all at one time with springs/struts/shocks, swaybars, and 4 braces including the AK. I can only tell you that the car is so much more connected to the road and driver. I am with Paul...watch for a used one, it's what I did and I'm very pleased with it. And God knows, you're the King of waiting for the right price on a used part... Nice CF engine cover
    Thanks,\
    Ed
    2012 A4 Avant... APR K04 /c APR tune, B&B catback, 034 HFC, 19" Avante Garde M510's, Bilstein B12 kit, Eurocode F&R swaybars/endlinks, Alu Kreutz, RS4'ish' Grilles, ERON rearview camera, EuroCode FMIC & plumbing, Kohlefaser Luft-Technik intake System, Ross-Tech VAGCOM, R8 coils, S-Line steering wheel /c paddle shifters, S4 F&R brakes /c drilled & slotted rotors/EBC's/stainless lines, LED taillights, Not a Mod, but WeatherTech laserfit floormats, 20% Tint, More to follow
    Veteran Member Three Rings khj677turbo's Avatar
    Dec 25 2007
    Tampa
    Affect on Power Steering vs Electric steering feel? I see both you guys with the 2012
    Current: 13 A4 P+ Sport, K04 etc, 18 SQ5
    Gone: 04 A4 1.8t USP 6-speed Avant
    Gone: 00 A4 1.8t K04'd
    Sep 09 2010
    Destin, FL
    Giant waste of money!Most will say they see results after changing parts out but most of the time it's just in your head. The cost vs results of this part is a no brainer, don't waste your time. Also, to say this helps with steering you obviously aren't very familiar with cars. In no way will this help with that since it's not even close to attaching to and steering linkage and it bolts tot he frame. the stock piece is solid and will not bend with turns, the after market piece is an expensive block of metal.
    Oct 26 2015
    Fremont, NorCal
    Shots fired!!..
    Yeah, from what I've read on the reviews, best guess is the overall effectiveness is mild to moderate at best. Given all the other suspension upgrades I've already sunk into mne, perhaps the thought of an AK may need to be shelved altogether.
    Thanks as always Infiltrator!
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by Poodini View Post
    Shots fired!!..
    I mean, if you want to try it out and who ever has it good for them. But I'm just saying it's not worth the cost vs results.
    Want results? Get a strut bar to go with sway bars.
    http://www.audizine.com/forum/showth...race-installed
    http://www.audizine.com/forum/showth...B8-A5-S5-A4-S4
    Senior Member Three Rings petraman's Avatar
    Apr 26 2016
    Columbus, OH
    Really? People have been talking up the AK like it'll transform your A4 into an Elise. At least in terms of steering feel. Which sucks, because the steering responce is terrible IMO.
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by petraman View Post
    Yeah it could be better. But I'm just saying this part will not fix or improve steering or handling at that.
    Jan 21 2016
    Hayden, AL
    Quote Originally Posted by The Infiltrator View Post
    ^^^I totally agree. I recently installed my suspension stuff and now have 2 front upper braces and a rear lower brace, but I got the AK for a song in a package purchase of swaybars/end links, AK and wheels, so for me it was a no brainer. Do I think it helps? Yes, I'm sure it helps a little & it is lighter so there is that benefit.
    But if asked... Would I buy one for full retail? My answer is unequivocally, NO.
    Thanks,\
    Ed
    Oct 26 2015
    Fremont, NorCal
    You mean like this?..
    Jan 21 2016
    Hayden, AL
    ^^^I have that one and the rear one as well...
    But I do have this one too...
    Thanks,\
    Ed
    Apr 26 2016
    Columbus, OH
    So... you're saying something like the CR-15 (is there even an alternative?) is a better upgrade than the AK?
    Oct 26 2015
    Fremont, NorCal
    That was literally the first DIY mod since joining AZ and I was blown away by how something as relatively simple like a support bar made such a noticeable difference in the steering!
    From what I'm gathering, the AK would be a nice compliment but simply not worth the sticker price.
    As it is, I've already beefed up with both the UR and CR upper braces, UR lower brace, 30mm H&R front/27mm ST Suspensions sways, plus 034's rear diff mounts + transmission billet.
    I don't think the AK is gonna be the magic unicorn that'll take it over the top but certainly will enhance the overall ride.
    for used one continues!!
    Realistically, if you could put a price tag more worthy, what'd y'all give it? Be interesting to see the numbers!
    Veteran Member Four Rings wxsgt's Avatar
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    Different car( I have a4 and S5 so I browse both) but where are link to those strut bars yall are talking about since they should be good for both the A4 and S5
    2010 Ibis White Audi A4 P+ l Upgrades: RS4 grill, Akebono Brakes, Debadged, Solo Werks S1 Coilovers, Targa Trophy Stickers(guaranteed 10+ HP) l
    2009 Ibis White Audi S5 Coupe | Upgrades: RS Grille |
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by wxsgt View Post
    Post 9
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    Post 9
    I don't see one for the rear I saw though
    Sent from my SM-G920P using Tapatalk
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    nvm found the ultra racing one
    Oct 26 2015
    Fremont, NorCal
    Here's a pic of the UR lower rear bar..
    So, my ? is, WHATS THE MOST YOU'LD SPEND ON AN AK??
    REACT!!
    Sep 09 2010
    Destin, FL
    REACT!!
    $10
    Veteran Member Four Rings B G 8er's Avatar
    Sep 28 2011
    2011 A4 Quattro Premium 6MT, 2016 VW Golf Sportwagen SEL Gone: 2013 Q5 2.0 Prem.
    Valencia, CA
    Long time. How you been?
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    Quote Originally Posted by B G 8er View Post
    been great, moved up got an S5 and the A4 now. how have you been
    Sep 28 2011
    Valencia, CA
    When I first added the Alu Kreuz, I noticed a small difference in that there was less flex during turn in. Later adding the EC sways, lowering the suspension and adding the 19's just magically brought everything together as a system. Think of the Alu Kreuz as fine tuning or icing on the cake. With the CR 15 which I added to everything else, that I could definitely feel tighter, added responsiveness in my steering. My power steering runs off the pulley though. Some of you with the electronic power steering may still feel less responsiveness.
    Sep 28 2011
    Valencia, CA
    See that! Congrats! How are you liking the Quattro over the FWD? Still just have the A4. Still looks spanking new and just about to turn 29k. Two more payments and she's free and clear. Sorry, didn't mean to jack this thread!
