Did search but did not find anything.
I had a slight leak at the oil return line fitting at the oil pan. I bought a new gasket from the dealer and decided to replace it when I changed the oil.
Took it apart, cleaned off the pan/line fitting, installed the new gasket, tightened the bolts and finished my oil change.
The leak actually now seems to be a bit worse! Did I miss something? Should I have put some RTV sealant on it or is the OEM gasket junk and I need aftermarket?
tks
