Results 1 to 21 of 21
    Senior Member Two Rings hayasa's Avatar
    Aug 25 2008
    S4 "active exhaust" ??
    Saw a few uses of the term in overseas press reviews of the B9 S4. What exactly is this and are we getting it in the US?
    Aug 25 2008
    So 300 views and no one knows? What I'm referring to is what the press is calling an "active exhaust" and in the past I believe this term was used to make it sound louder via the Drive Select, but this was a fake sound pumped in through the Soundaktor. But since the new S4/S5 is said to not have the fake sound generator any more, I wonder what they are referring to. In other words, does the B9 exhaust have valving to make it louder under exceleration al la the RS5?
    For reference, notice the extra stuff (black boxes, metal cylinders, etc.) at the tail end of the exhaust attached to the mufflers:
    2018 Audi ??? (TBD)
    1990 Audi Coupe Quattro rallycross car - SOLD
    2008 Audi S4 - SOLD
    I like my women like I like my roads: curvy and well lit.
    Senior Member Two Rings dbuxton13's Avatar
    Apr 20 2016
    Germany
    Any links to source? No idea honestly, and online searches come up empty. In one of the videos I have watched the reviewer showed how the exhaust note changed when switching to sport mode, which denotes some kind of valve switchology.
    B9 S4
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Quote Originally Posted by dbuxton13 View Post
    The pictures do show electronic exaust valves.
    Sent from my Nexus 7 using Tapatalk
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Nov 15 2010
    Audi RS4 2.9 TFSI MY2022
    Oslo
    Exactly it's more than a exhaust valve at the back of the muffler controled via audi drive select.Loud in dynamic / quiet in comfort.
    MY22 B9.5 Audi RS4 Avant / MY19 Fiesta ST
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    I'm sure we will be seeing an AWE Switchpath at some point ;)
    Aug 25 2008
    Just one of a few reviews below. I think there was an interview with an Audi rep who said something similar.
    "A key design element of the S4 is the quad-pipe arrangement, coupled to an active exhaust but no sound actuator, meaning the engine note is always ‘organic’."
    Also this one:
    "This new V6 feels more awake than the supercharged 3-litre ever did, and it comes with a hearty howl to match its newfound potency – especially with its optional Sports exhaust’s flaps opened to full shriek mode."
    2018 Audi ??? (TBD)
    2008 Audi S4 - SOLD
    Veteran Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Q5 3.0T
    i hope it is like whats in the TTS
    2010 A4 quattro, Tiptronic, Ibis White
    Aug 25 2008
    Found another cool image of the exhaust, and what really appears to be a valved system. Seems like there is a valve between the split on the drivers' side, and another valve between the two exhaust tips on the passengers' side.
    2018 Audi ??? (TBD)
    2008 Audi S4 - SOLD
    Established Member Two Rings Ricky Ricer's Avatar
    Apr 16 2015
    Lakewood
    This is nothing new. Audi has used exhaust flaps on almost all S models for quite some time.
    -Rick
    Audi Denver/MAG
    Veteran Member Three Rings sirsycott's Avatar
    Sep 20 2013
    Orange County/CA
    Quote Originally Posted by Ricky Ricer View Post
    minor correction to that blanket statement
    b8 and b8.5 S models didn't have it
    Aug 25 2008
    Quote Originally Posted by sirsycott View Post
    And I had a B7 S4, also without the flaps. Only the RS models had it if I remember - B7 RS4 and B8 RS5.
    2018 Audi ??? (TBD)
    2008 Audi S4 - SOLD
    Apr 20 2016
    Germany
    So in other words, this *is* something new.
    B9 S4
    Sep 20 2013
    Orange County/CA
    at least it's not the fake speakers mounted inside the exhaust like the TDI cars
    technically still better than soundaktor playing through your speakers in the car
    Apr 05 2012
    Earth
    The Soundaktor doesn't play through the speakers; BMW's system does that. The soundaktor uses the firewall and windshield to amplify and project the sound. The actual device is mounted under the hood against the firewall.
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I think it's when you press the gas a certain percentage the exhaust valve opens up.
    Apr 05 2012
    Earth
    So it's like the exhaust on the BMW 335i where it has dual exhaust but the left one only opens above a certain RPM?
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Quote Originally Posted by JohnEnglish View Post
    Thats exactly what I was thinking (the 335i) but maybe opening based on throttle position.
    Aug 25 2008
    I think it appears to be a 3-stage system - both valves closed (light throttle), tail pipe valve opens (moderate throttle or Dynamic Mode engaged), and split valve and tail pipe valves open (full throttle).
    2018 Audi ??? (TBD)
    2008 Audi S4 - SOLD
    Senior Member Two Rings dave329's Avatar
    Nov 18 2011
    Woodside, NY
    Looking at this video at the 22 min mark you see him testing the launch control and can clearly see all the exhaust smoke coming out on one side. The second he releases the brakes and takes off you see both exhaust pipes pushing smoke out.
    https://youtu.be/Sgymjj6-ZT0
    2021 SQ5
    2016 S6, Prestige, Mythos Black w/ black int, Sport Package, Black optics SOLD
    2014 A6 - SOLD
    2012 S4 - SOLD
    Aug 25 2008
    Finally, I can confirm that the B9 does indeed have a valved exhaust! Went to the LA Auto Show and they had an S5 on display. Took a photo of the right tailpipe and you can definitely see an open valve. Also got to play around with the virtual display and all the gadgets - and the car is spectacular. Audi seriously raised the bar on this one and it really made the competition look hopelessly outdated and boring.
    2018 Audi ??? (TBD)
    2008 Audi S4 - SOLD
