Results 1 to 10 of 10
Thread: Maestro Help
    Nov 10 2006
    B7 A4
    Detroit Michigan
    Maestro Help
    I bought a secondhand ecu with maestro. I'm trying to load 2-step anti-lag. There is two options I can click. The first option on the left works but when I click the second option a warning comes up(2step damage warning) and closes the window down. What am I missing ?
    Sent from my 831C using Tapatalk
    Mar 24 2013
    Oakdale, CT
    I was never able to get it to work. Tapp was no help either.
    -Adam
    Nov 10 2006
    B7 A4
    Detroit Michigan
    Could you click both 2step options or did it do the same thing? Even if it makes the ecu not work that's a good enough sign for me lol
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    The mk5 forums are decent help. The walk through claims is just a warning. Not sure what the specific order was to be clicked in order to activate. I have 1 file that I got it to work on when I had the last turbo used it 1x and it sounded insane so I just scratched the idea and left it alone.
    If U can get no lift shift to activate I think your set. Somehow the 2 work hand in hand.
    BPY H file might have something to do with it. Shoot me your email in pm when I'm home I can send the file that I had that worked.
    Nov 10 2006
    B7 A4
    Detroit Michigan
    Thank you sir!
    Feb 10 2012
    parts
    Napanee, ON
    Did the file help at all??? Im still unable to find my cable.
    Nov 10 2006
    B7 A4
    Detroit Michigan
    I haven't tried it yet. I'll start loading it up now. It takes a long time vs bdm.
    Nov 10 2006
    B7 A4
    Detroit Michigan
    Hmm do I have to unplug my maf to use this ?
    Dec 23 2011
    You shouldn't have to be mafless for it to work
    Nov 10 2006
    B7 A4
    Detroit Michigan
    OK I'll check it out. Thank you.
