Results 1 to 12 of 12
    Aug 19 2013
    minnesota
    5 speed gear oil level
    Wondering if peering into the sight hole on the 5 speed I can verify the level? Not that there's a leak, just wondering.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    You can't really see into the fill hole. Just stick your finger in and see how far below the level of the plug the oil is.
    Apr 17 2016
    kc
    How far is it supposed to be, just a hair beneath?
    Dec 28 2006
    Western Maryland
    You fill it to the level of the open drain plug hole.
    Aug 19 2013
    minnesota
    I read in another thread that the fill line is 1 millimeter below the fill hole. So there's three holes on this thing.. There's the sight hole, the fill hole and the drain hole.
    Aug 19 2013
    minnesota
    As I recall rather than remove the fill hole I just poured 3 liters in since I drained it upside down.
    Dec 28 2006
    Western Maryland
    If I recall correctly the 5-speed holds 2.7 liters. Simply remove the fill hole plug and see if anything runs out.
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Quote Originally Posted by jacobsen View Post
    I think you might find that the site hole and the fill hole are one and the same. I'm pretty sure they didn't put a whole nother hole, wholly for the sake of checking the fluid level.
    Pro Tip: Never use the hole on the bottom to check your fill level.
    Real Pro Tip: Make sure the fill plug comes out before draining.
    Aug 19 2013
    minnesota
    Quote Originally Posted by Kevin C View Post
    There's 3 holes. Plastic sight hole, fill hole and drain.
    Mar 28 2015
    http://www.pelicanparts.com/techarti...uid_Change.htm
    Do mean the hole filler for vehicles that don't have a speedometer sensor built in the transmission? Its to the right of the fill hole.
    Other than that, I have no clue... Got link showing the plastic mystery hole?
    Aug 19 2013
    minnesota
    I guess that's what I'm talking about. That plastic plug with the O-ring on it and the little arm that locks in place right next to the fill hole is what I was referring to. I had no idea what it was for. Mine does not have a sensor on it. It's simply a plug.
    Dec 28 2006
    Western Maryland
    The '02 B6 utilizes a VSS (Vehicle Speed Sensor) in that location. From '03 on the VSS signal comes from the left front ABS sensor and consequently there is simply a plug in the VSS hole.
