Results 1 to 8 of 8
    Established Member Two Rings DirtyVegasTT's Avatar
    Apr 29 2009
    Vegas
    Anyone running RS Turbos + Tune without Downpipe?
    I was told that RS and S8 Turbos are the same. If so, I'm thinking of maybe moving to bigger RS Turbos in my A8L 4.0T, but I do not want the dealer to know that I have done any work on the engine. I think sticking with OEM RS Turbos I would be safe if the car was inspected, but Downpipes would definitely give the modding away.
    So, anyone running RS Turbos without Downpipes and is it worth it?
    2013 A8L 4.0T
    APR | 22x10.5 Vossen VFS1 | 285/30/22
    Gone - But Not Forgotten
    2007 S6 V10
    APR | Miltek Catback | MSDS Filters | RS6 Grill | LLTek Spoiler | H&R Sport Srpings | 20x9 Hartmann B7 HRS4 | 265/30/20 BFG G-Force
    Mustang Dyno: 342 AWHP, 338 AWTQ - Back then it was pretty good for N/A Audi
    Feb 14 2014
    13 S6, 13 Q5, 72 Chevelle
    Oklahoma City
    Not doing down pipes in theory should be perfectly fine. The RS7 in stage 1 does just fine with the stock down pipes. You would just need to get Simone to do a tune for that setup
    Feb 14 2014
    Oklahoma City
    Not doing down pipes in theory should be perfectly fine. The RS7 in stage 1 does just fine with the stock down pipes. You would just need to get someone to do a tune for that setup
    Veteran Member Four Rings sciblades's Avatar
    Mar 20 2009
    North Salem/Palm Beach
    Quote Originally Posted by DirtyVegasTT View Post
    Rs7 and s8 turbos are not the same they are different part numbers
    Issue you run into is anyone selling a tune for rs turbos will assume you have a downpipe so asking the company to rewrite a tune for you might be costly
    Sent from my SM-G935U using Tapatalk
    2016 RS7 Stinger VIP laser and radar, Unitronic Stage1+
    Gone
    2013 C7 S6- v1 and LI- Unitronic tuned]
    B8 S4
    06 a3 Full Votex Kit, Unitronic III, apr tbe, precision 750 FMIC, apr HPFP forge dvi, EVOMS cai, BSH gt3076r turbo kit, IE rods, sb stage IV, LSD, on meth
    Apr 29 2009
    Vegas
    Quote Originally Posted by sciblades View Post
    I should have double checked that info after hearing it. Thanks for clarifying! I just need to get an S8...
    2013 A8L 4.0T
    2007 S6 V10
    Mar 20 2009
    With the price of the euro down I suggest doing the rs it is only 2k a turbo right now
    Gone
    B8 S4
    Apr 29 2009
    Vegas
    I thought you said it was a different part number so I assumed it would not work. Will RS turbos work on the A8 4.0T? Where are you guys sourcing the RS turbos from?
    2013 A8L 4.0T
    2007 S6 V10
    Sep 10 2015
    VA
    If stage 2 requires down pipes then I would think stage 3 would require them too. I asked a while back about is downpipes are really needed on such a small increase in the tune and everyone said yes even though some said the down pipes were the same on the RS models!
