Hi Guys,
In the past few weeks I've gotten the follow error codes that even after clearing seems to return. Initially the car would not start unless the start button was depressed though the entire start/crank process. If I simply hit the button the car dies and does not start. Also the car does not go through the start up high rpm process since this code showed up.
I'm looking for guidance before I take it in for service so I'm not completely in the dark.
As a little back drop the engine was replace under warranty about a year ago and has less than 3k miles since that event. Also the Transmission Park Selector switch was also changed under warranty about 1 year ago also under warranty.
Of course all this is happening after the warranty expired in May and I opted not to get an extended warranty as my reasoning was the two major components had recently been serviced.
So my question is - do I have a leg to stand on with Audi in getting these issues fixed being that these issues are occurring with less than 2k miles of all of that major work being done?
Thanks in advance for any help guys.
OBD2 - confirmed:
P0010 - "A" Camshaft Position Actuator Circuit/Open Bank 1
OBD2 - pending:
OBD2 - permanent:
Body/convenience system:
00230 - Transmission Park Selector Switch (F305)
