Results 1 to 10 of 10
    Feb 20 2012
    Portland, Oregon
    vehicle speed sensor
    I have a 2005 B6 S4 avant and the speedometer has been going out and errors on vagcom have come up for the vehicle speed sensor. I was going to order a new one and wanted to find out if this is something that can be easily accessed from under the engine to replace or does it require more work than that to access it.
    Feb 20 2012
    Portland, Oregon
    One other thing to add is that are abs errors also and I read recently that these cars actually do not have a vehicle speed sensor, but information cones from the abs sensor. Is this true?
    Apr 26 2016
    Kia Sportage V6 - Wifes car
    Metuchen New Jersey
    each wheel has a sensor and ring.. the rings are on the CV joint closest to the wheel, and the sensors are usually on the back side of the hub or knuckle.. the sensor sends wheel speed to the abs module.. what codes are you getting?
    Sent from the S4 with a Tap!!!
    My S used to have a tap, a valve slap... now it makes no noise at all! RIP
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    Just changed mine. Took 20 minutes each. Hope your ABS isn't going bad. 150.00 repair with Matt at CheapABS.com fast turn around as well.
    Veteran Member Four Rings A U D I's Avatar
    Nov 13 2012
    Chicago
    Quote Originally Posted by mbagge01 View Post
    This is true. You need to check that the speed sensor is the problem and not just coming from the ABS module instead. Usually will be a fault code that comes and goes randomly until it faults completely in the module.
    Feb 20 2012
    Portland, Oregon
    These are the vagcom errors.
    18057 - Powertrain Data Bus
    P1649 - 008 - Missing Message from ABS Controller - Intermittent
    16885 - Vehicle Speed Sensor
    P0501 - 002 - Implausible Signal - Intermittent
    18259 - Powertrain Data Bus
    P1851 - 000 - Missing Message from ABS Controller - Intermittent
    18256 - Please check DTC Memory of Engine Controller
    P1848 - 35-10 - - Intermittent
    01316 - ABS Control Module
    49-10 - No Communications - Intermittent
    01312 - Powertrain Data Bus
    79-10 - Please Check Fault Codes - Intermittent
    Apr 26 2016
    Metuchen New Jersey
    imo, your module is about to shit the bucket
    Feb 20 2012
    Portland, Oregon
    Is the ABS module difficult to remove on this car, or are there any guides on doing it without having to remove the entire ABS unit.
    Senior Member Three Rings Badger Audi's Avatar
    Feb 05 2014
    B8.5 S4
    San Diego, CA
    You can change the speed sensor fairly easily. Took me probably 30-45 min when I did mine on my old B5 A4.
    Current:
    2013 Audi S4
    Previous:
    2005 Audi S4 - sold
    2012 Audi Q5 Premium Plus - sold
    2004 Audi A4 Quattro 6MT - sold
    1997 Audi A4 Quattro 12v - sold
    Apr 26 2016
    Metuchen New Jersey
    the module isn't that hard to remove, and you can do it with out having to disconnect the break lines.. there's a diy on audizine on how to remove it.. if your mechanical, should take you about 45 min to an hour to remove it.. its 6 screws and the module will come off. 4 you can get from under rhe hood, and 2 from the fenderwell, just make sure you cover the rest of the unit after you separate the module from it.
