Let me just start by saying someone is about to get an absolute DEAL.
I need this car gone THIS WEEK. I have more than $20k worth of receipts to go with this thing.
Basics:
- Casablanca White / Black Onyx
- 6mt
- 132,xxx miles
- 3rd owner
- Clean title in hand, vehicle history reports will be provided for any serious buyers
- No accidents
Maintenance:
- Bosch primary O2 sensors @ 100k
- Front outer CV boots @ 100k
- OEM Valve cover gaskets, rear cam tensioner seals, & cam plugs @ 105k
- Timing belt, aux water pump, thermostat, drive belt, & tensioners @ 105k
- Intake/exhaust lifters and cams @ 105k
- Cam position sensor & coolant temp sensor @ 120k
- Aux. Water Pump delete @ 124k
- Hitachi MAF sensor @ 130k
- Brand new Akebono Ceramic pads front/rear - included but not yet installed
Modifications:
All modifications were performed at 105k:
Motor:
- STOCK MOTOR
- Tuned by the late Daz @ VAG Autowerks
- SRM v2.0 K24 RS6 hybrid turbochargers
- SRM inlets w/ Induktion oil feed lines
- SRM side-mount intercoolers
- XS Power RS6 3" v-band downpipes
- Custom dual 2.5" Magnaflow exhaust
- OEM Audi R8 coilpacks
- Custom billet coil adapter plates
- 034 coil conversion kit w/ ICM delete
- NGK BKR7E .025"
- Darkside Developments 5 bar MAP sensor
- Samco TBB
- Bailey's diverter valves
Fueling:
- Bosch EV14 72lb. injectors
- Bosch 044 fuel pump w/ V8 basket
- Project B5 90mm MAF & intake
- Zeitronix ZT-2 wideband
Drivetrain:
- Ringer-Racing Stage 4 clutch kit
- AWE aluminum lwfw
- USP metal slave cylinder w/ stainless line
- 034 street density motor mounts
- 034 street density trans. mounts
- 034 snub mount w/ cage
Exterior:
- Depo E-Code H7 headlights
- Morimoto Mini H1 6.0 bi-xenon projectors
- Custom projector mounting brackets
- Morimoto 3five DSP ballasts
- Morimoto H1:XB35 5000k bulbs
- TRS high-beam splitters
Interior:
- Zeitronix ZR-2 multi-gauge display
- Zeitronix 5 bar boost sensor
- Zeitronix ZAVT-1 trigger/warning box
- Podi steering column gauge pod
- DICE iPod/iPhone integration
- Krauto LED interior lighting kit & plate lights
- B7 rearview mirror w/ compass
- AWE Tuning pedal set
Wheels & Brakes:
- (5) OEM B7 S4 18" wheels
- Continental Extreme Contact DWS 225/40/18 tires 80% tread
- ECS Tuning 10mm wheel spacers
- Brembo rotors w/ Akebono ceramic pads
Condition:
Exterior 8/10. The paint and body are in great shape. No accidents. There are some small dings and scratches around the car, most of which do not show from more than 12 inches away. The wheels have some curb rash and could use a refinish. No rust anywhere.
Interior 7/10. Tear on the driver's seat left abdomen bolster, passenger and rear seats are essentially perfect. Headliner will need to be reupholstered. All controls function as they should. Heat blows hot and the AC blows cold. A few pixels missing from the center display, but readings and warnings are still completely legible.
The car does have some issues that need to be addressed, hence the HEAVILY discounted price:
1. Needs an ABS Module
2. Needs an Airbag Module
3. Needs a front passenger window regulator
4. Coolant level warning light comes on but there are no leaks
All of this work should cost well under $1k even paying a shop to have it done. No CEL. Mechanically the car is sound and runs great. Just drove it 600+ miles over the weekend.
I NEED THIS GONE BY 9/16. Available to view in either Louisville KY or Northeastern PA. $8k. NO TRADES. Already bought a new STi so please do not ask. Genuine VCDS cable and generic eBay flashing cable included as well as any spare parts that I have. Car is super clean and all issues are cheap fixes! Let's get this thing sold!
Please PM me with further questions and I will provide you with a phone number.
