Results 1 to 13 of 13
Thread: Won't start
    Active Member Two Rings NickSaieg's Avatar
    Nov 19 2015
    edison nj
    Won't start
    Hey guys back with another post which unfortunate means my car is broken again :(. You guys are life savers so here we go. Today I went to start my car after classes and it started up fine. I let it warm up setting up the song I wanted to listen to and when I'm ready to go I put it in drive and the car shudders the rpms drop and it dies out. The worst part is that I could get it running afterwards and took a train home help anybody?
    Sent from my A0001 using Tapatalk
    Veteran Member Three Rings kwnk's Avatar
    May 21 2011
    '03 SV650S, '76 280z
    Does it start up and idle?
    Does the power shudder/cut off when you rev the motor?
    Could be a possible fueling issue -- either a clogged filter or dying pump
    1999 1.8TQM Avant | H&R Coilovers | 034 1bar tune | 16" URS4 Fuchs | Forge 008 | Borla
    Nov 19 2015
    edison nj
    Quote Originally Posted by kwnk View Post
    Car doesn't start anymore. I had to leave it after 10 min of trying to start it. I have had some studdering issues. How should I Check?
    Senior Member Three Rings Badger Audi's Avatar
    Feb 05 2014
    B8.5 S4
    San Diego, CA
    When did you last do the plugs and wires? We're your studders at lower RPMs? Misfiring cylinders most likely..
    Current:
    2013 Audi S4
    Previous:
    2005 Audi S4 - sold
    2012 Audi Q5 Premium Plus - sold
    2004 Audi A4 Quattro 6MT - sold
    1997 Audi A4 Quattro 12v - sold
    Nov 19 2015
    edison nj
    Quote Originally Posted by Badger Audi View Post
    But how does the car go from misfiring to not starting at all? And I did plugs and coil packs maybe 800miles ago never wires.
    Feb 05 2014
    B8.5 S4
    San Diego, CA
    I would check your wires for any frays or defects. That is where I would start at least. I had an issue with my b5 dying on me but then starting back up and all was OK - it also suffered from the misfiring cylinders and new plugs and wires fixed my problem. It still idled heavy though..
    Current:
    2013 Audi S4
    Previous:
    2005 Audi S4 - sold
    Nov 19 2015
    edison nj
    Mine won't start at all
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    I would check fuel pressure at the rail, as well as the above mentioned diagnostic checks (plugs, wires, ect)
    2016 S3
    Instagram- @Thisisastickup
    Nov 19 2015
    edison nj
    Quote Originally Posted by b6Hate4 View Post
    Okay since I'm a complete noob how would I go about checking all these things? I'm going to have my gf drive me tomorrow and check the car out
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by NickSaieg View Post
    Autozone sells a kit, which unfortunately is about $60, but you may be able to rent one too. There is a schrader valve (same valve as your car tire), you connect the gauge to that test port and crank the engine, you should see pressure build to around 60 psi.
    2016 S3
    Oct 27 2010
    Norwood, MA.
    Test port is at the back of the fuel tail towards the firewall. It will have a black cap on it similar to your car tire.
    2016 S3
    Nov 19 2015
    edison nj
    Okay I'm going to stop by autozone and ask about the kit. How close to 60psi should I be getting? And how do I Check the wires?
    Oct 27 2010
    Norwood, MA.
    Found this for ya
    Sent from toilet stall #4
    2016 S3
