Results 1 to 1 of 1
    Veteran Member Four Rings MMMB00ST_A4's Avatar
    Mar 31 2009
    NC
    2002 Volkswagen GTI 337 Edition Hatchback - $6,000USD
    Up for sale is my beloved 337 with 144k miles. Its been an awesome ride thus far. The car recently had the clutch and flywheel replaced with a Valeo Single Mass Clutch & Flywheel. The kit included a Valeo solid flywheel, pressure plate, clutch disc, throw-out bearing and flywheel mounting bolts. Other than that just drove it everyday and changed the oil and plugs regularly. Wheels can be re-powdercoated any color very cheaply(buyer's expense). It has the following mods:
    ENGINE:
    BMC Carbon Fiber canister intake (18k)
    APR Stg 1 software w/5 different modes changeable through the cruise control (about 30k)
    Milltek Cat-back exhaust with resonator delete
    42 Draft Designs Race Series 3" Down-pipe and Catalytic Convertor
    NGK BKR7E's to prevent detonation
    New Battery
    1.8t painted engine cover (bmp color)
    Valve Cover gasket Kit, Camshaft Tensioner Gasket, All Engine Hoses Replaced, Alternator, Mass Air Flow Sensor, Timing Belt, Timing Belt tensioner, Timing Belt Tensioner Roller & Water Pump Replaced (110k)
    BRAKES:
    VW OEM Pads all around
    Stainless Steel Braided Lines (urethane coated)
    SUSPENSION:
    Brand new oem mounts/bearings all around (72k)
    Koni Adjustables all around with stock 337 Eibach springs (72k)
    Front/Rear stress bars (forgot the brand name) made of polished aluminum
    Car handles so much better with this setup. PERFECT DAILY/PERFORMANCE SETUP!
    TRANSMISSION:
    Valeo 240mm Single Mass Clutch & Flywheel
    BODYWORK/EXTERIOR:
    Both sides resprayed because of dings
    Zender front bumper (discontinued hard to find!)
    Helix Smoked Projectors with 6k HID's
    Hella smoked Tail lights
    18x8.5 BBS RGR's powder coated Cosmic Blue wrapped in 225/40 Tires
    5mm spacers in Rear
    INTERIOR:
    Phatnoise 40GB Phatbox
    VDO Boost Gauge with New South Steering column Gauge Pod
    Stock 337 Lemans Red Striped Interior
    If you have any questions or would like to see the car then please let me know. The price is pretty firm. Please keep in mind that the car is almost 14 years old so you will find your casual nicks and dings on the exterior. Interior is fairly clean but has the casual fabric sagging on the door panels. No joy rides please and I am available to show the car during the week. Thank you.
    -Brandon
    APR | Oettinger | KW | iForged | Evolution Racewerks | Labree | Carbinio
    12.9@104mph
